Received my IF22A - the battery charge level indicator is not working properly. It shows steady red, right after fully charging the battery inside the flashlight for several hours and turning the light on. I know the green LED works, as it shines green after fulling charging the light. I’ve fully tightened all of the connections - it is still steady red when I turn on the light. I’ve also tried opening up the light and removing the battery, then re-inserting it. Looks like this light will need to be returned to the seller. I’m very disappointed, as it seems like a great light, other than that problem.
Thank you very much. The seller has also reached out to me for a solution. I appreciate your company standing behind your product and doing the right thing to resolve the issue.
I need to send the codes to above who had left a comment before you! I’ll send the code to you several days later. Thanks for your patience and understanding! :innocent:
