Hey Jackie.
Is it possible for me to buy the SP40A tir optic alone?
Earlier in this thread you said you would make a listing on aliexpress.
Thank you.
Hi, i have updated a link, photos will update soon:
8 degrees ?! A toss instead of a spill, or a typo again?
Jackie, would you happen to have a tool to help in unscrewing the SP40 bezel?
I have removed the bezel from an earlier SP40 (XPL-HD) before (it got a few scratches).
but when I tried to remove a newer SP40 (LH351D), I had trouble removing it (I do not want to scratch the bezel…)
Jackie, would you happen to have a tool to help in unscrewing the SP40 bezel? I have removed the bezel from an earlier SP40 (XPL-HD) before (it got a few scratches). but when I tried to remove a newer SP40 (LH351D), I had trouble removing it (I do not want to scratch the bezel…)
Try to turn on Turbo for a couple of minutes, and unscrew it by resting on slippers or a rubber mat ... I did just that, and it was with SP40 (LH351D)
Can you tell me about the PWM on this SP10V3.0? I had one of the older AA/14500 lights and the PWM was so bad that I gave it away, gave me a headache.
will check with our engineer on Monday
get a reply now : about 20khz
Pressing it into the bottom of a mouse pad or a rubber jar opener has worked well in my experience.
I started off using snap-ring pliers, and also scratched the bezel. Then I found out friction is often enough, and it made modding a lot easier.
15% code work for SC21 :
3IXIOYXLLR8R
SP40 /SC31 PRO Deal price now
Thanks Jackie, orders placed.
thanks for support
IF22/IF22A/TS21/SC31T/LT1/SC21/SP36PRO/Q8PRO/FC12/DL10R/SD05/HD20/SD01PRO/HS05/WK30/S11
Code for all models above : L9BWVAC5IN0T
The old code did mot work. Do you have a new code for the New SP10V3? Thank you
L9BWVAC5IN0T update this one for SP10V3
Just tried code for the IF22A on Amazon US and it did not work. Do you have another code? I would really like to purchase this light! Thank you
Amazon code was ended, here update a 15% code on Aliexpress : AID9YVQUARKK
