The 3rd gen should be just around the corner, with both XHP50.3 HI and XHP70.3 HI, even the domed versions probably will have a better beam color profile since there is no phosphor pour over the whole package. So at this point it’s better to wait a bit and try to source those in high CRI instead of going with the soon to be obsolete 2nd gen.
Whoa! That's insanely snot green! Even the hotspot looks greenish LoL. They really @#$%ed up with the second generation.
I hope for the above beamshot to exaggerate the actual appearance of the beam, because if it literally looks that way to the naked eye I really wonder how someone is willing to deal with it. For comparison purposes, just took my M1 build with White Flat 1mm² (CSLNM1.TG): hotspot is white, corona is a tiny bit greenish and spill is slightly bluish to my naked eye, but nothing major. By the way, I also noticed it needs a new centering gasket, the one I originally stuck in is asymmetric and can be seen in the beam. You can guess I haven't used it much… O:) And then, the beam from my orange peel red S21A with 3500K GA3 SST-20 is absolutely beautiful.
How’d you manage to get that shipped to the US? Pretty slick light. I can’t even see the listing for it unless I follow a google link with no ali in cookies/history…otherwise it blanks it out because he’s honoring that patent and won’t ship here (same happens on Banggood lately).
Might look to see if that emitter was covered in Djozz’s tests but a quick peek at the data sheet for it says a max of 1.4A and with UV emitters that max is usually accurate (as opposed to white emitters which we happily overdrive the heck out of). That driver would optimistically give 2.5A per emitter which I suspect would fry them in short order unless legit tests have shown otherwise. Not sure I’d push 2A on them if they’re anything like the ones from Nichia and LG in terms of respecting that current max on the sheets. I think his 6A drivers would be fine, maybe use smaller wires and remove any spring mods if present. Seems like that driver puts out something around 5.6A or so based on other comments here.
Guess you are speaking about the “8A driver for CULPM1.TG”, doesn't it? That is a buck driver, it will deliver the full output current for as long as its input voltage is high enough. In this sense it behaves as the linear variable load drivers like the 6A units you mention, if only with higher efficiency as it is a switching driver.
Correllux says “optimistically 2.5A per emitter”, I guess you are talking about a triple. But 8A / 3 = 2.6̅ = ≈2.667A, which is slightly higher. Don't presume, but measure.
If you want to make 100% sure that the driver doesn't frys your emitters the key is to change its onboard sense resistor. For this you first take a close look at the driver board, find the sense resistor and note down its value. The sense resistor is a bigass, low value precision resistor which should be near the edge of the board. I think it is a 10mΩ unit in such driver. Then, you calculate the driver's sense voltage: Vsense = I × R, and so Vsense = 8A × 10mΩ = 80mV. With this in mind, you can now calculate the maximum regulated current for other sense resistor values: for 20mΩ, I = Vsense / R = 80mV / 20mΩ = 4A; for 18mΩ, I = 80mV / 18mΩ = 4.4̅A = ≈4.444A; for 16mΩ, 5A; for 15mΩ, 5.3̅A = ≈5.333A…
Just in case it is of help had this link with 1206 R015s for sale in my wishlist, which is nice enough I think. However, I do not know 100% sure if the onboard sense resistor is 1206… O:)
By the way, I wouldn't build triples in parallel, it's waay better to set them in series and use a boost driver, because:
With leds in series the current is exactly the same for each emitter.
A boost driver (like this “XHP35” one) ensures full output drive current and power regardless of input voltage or battery state of charge (as long as it meets the bare minimum, of course).
Of course you need a compatible size and arrangement triple MCPCB (KD has this thing, but no idea if it would fit).
wow, thank you for this great info, Barkuti! I won't use it for UV anything (no interest in uv atm), but I will use this for other 3x/4x emitter builds + adjusting driver outputs! Appreciate it!
The VF value of UV LED is much higher than that of ordinary white LED. I use a 6A drive and the test result is 2.4A current.
I have not try 8A driver, The current should be higher, maybe 3-4A
Simon, I see you’ve released a remote switch for L21B. Is it possible to remove the remote switch from the L21B tailcap and install it in any other Convoy 21700 flashlights with a tailswitch? Perhaps S12 IR?
Are you speaking about the 12-groups switching buck driver with up to 8A output?
Despite what Simon says, using a high current driver means that if the conditions are met (this is, enough effective input to output voltage difference, and low enough emitter Vf), the current at the emitter could go above the maximum it can tolerate. When I say “effective” I say it because the input voltage at the driver diminishes as the input current goes up, because of current path resistances (springs, switch, etc.).
The correct solution is always to adjust the output current at the driver, this requires adjusting the sense resistor value in it. The advantage of this approach is that all the driver modes will upscale or downscale proportionally. For the 12-groups high current buck driver, swapping the stock R010 with a 40mΩ unit (R040) nets a maximum of 2A at the output, and with a 33mΩ one (R033) the maximum output current would be 2.4̅2̅A = ≈2.425A.
