It is definitely more flood than throw. Has better throw than the Thrunite T2 but that isn’t saying a ton. Anyway, I would totally buy a sc700d model with a TIR optic. It’d be sweet.
I suspect a lot of people are doing what almost always happens to me when I look at a flashlight picture, and perceiving it as bigger than it really is. Keep in mind how compact a D4v2 in the photo is.
That said, it had to be at least very close to the size it is for the features it has. I’ll repeat the math I posted over on the flashlight reddit:
Hank already mentioned he chose a 40mm head. It will get a little more throw than what a 35mm head like the KR1 and original D1 had - that’s a pretty straightforward tradeoff that some will prefer, and some won’t.
For length, consider our D4 again as the starting point:
95mm
5mm to go from 18650 to 21700
18mm (my estimate after looking) to go from Carlco 10mm quad to 35+mm single TIR
2mm to allow for the height of the inductor for a boost driver
120mm
To double-check that - the K9.3 is 124mm long. A quick scaling check on the photo puts the new light at 4-5mm shorter.
It doesn’t seem like this light can get much smaller without trading a little bit of throw (smaller optic) or battery capacity.
I really appreciate the enthusiasm from reddit users, but for some reason, I’m not able to view Reddit recently, .
DM stanads for D and M series combination.
The price should be $55~75 depends on the versions.
This is prototype, but it’s 95% the same as the final version, the length is 120mm.
If the reaction from Reddit is any indication, you’re going to sell a ton of these lights - especially at that price!
Honestly this seems like it will be a great light for my uses, between the size and the B35 option, I’m very excited to try it out when it becomes available.
Of the emitters you’re offering in this light, do you have a personal favorite?
Very exciting! Hank, is there any extra cost when custom ordering with channel switching or ramping (besides the varied cost of different emitter options)?
Hank, what is the output of this newdual channel D4sv2 driver (tint shifting, not ramping)? Is it 9amp CC? is that 9amps per channel ? (meaning 2x leds on channel one get 9amps while ON, and 2x LEDs on channel 2 get 9amp while ON?)
If doing an osram W2 version of new D4sV2, 9amp for 2x led's is fine, but so is FET if proper battery is used (green and white W2 can handle 7.5amps each = 15amps capacity). How should we order, what notes do you need to know?
