[Design with Terry]Wurkkos TS32 15000+ Lumens Flashlight Concept
158 posts / 0 new
kokosnh
Last seen: 1 week 1 day ago
Sold separately handle mount to the tail, I didn't think of that, I like it.
So now My wild Idea base on that and current design, to allow for it.
Make that grooves on the battery tube at angle, and make a big thread out of it. The handle would just screw in it, and have a holes (3 or 4) for couples screws or something, to threads through it, and go in that 7 or 8 (from render i count 7) larger oblong groves in battery tube.  So you can lock it into place, that holes in base of the handle would have to be long vertically, so you can lock the handle directly over the switches. That design could allow that. That Nitecore have just 2 part base handle, but i think it's weak, you just need a long vertical hole of size of length between the large oblong groves )
Of course, the portion before the start of the grooves on the battery tube, would have to be shallower, than threads.
That design would allow for the handle to be moved closer, and further, from the switches, as well, to move right and left from them. So we can have one handle for large and small hands, and you can move the center of gravity to your preferable spot, for handle.
And the locking screws  would not be load bearing, it could be screws with rubber tip, to not scratch surface. Or some other type of rotation locking mechanism.
There Is also one handle design that would work with the current design, just have a hinge, and a screw, to lock the base of it to the tube.
Ps.  saw this now, a TIR optic, and single battery (which is probably bad idea, but then again, he probably used his NOCTIGON K9.3 base)
https://www.reddit.com/r/flashlight/comments/ptksww/how_about_a_noctigon_k141/
Pps. and we are getting close cheaper and better version of fenix LR40r
 https://www.fenixlighting.com/product/fenix-lr40r-flashlight-12000-lumens/
Mblackes
Last seen: 1 hour 26 min ago
Any updates?
nbjly
Last seen: 21 min ago
How about an LEP in the center? I haven’t seen that yet -
stephenk
stephenk's picture
Last seen: 11 hours 24 min ago
A tripod mount would be a good addition. Sustained brightness >2000lm should be aimed for.
Wurkkos Terry
Wurkkos Terry's picture
Last seen: 2 days 3 hours ago
Mblackes wrote:
Any updates?
Yes, now we are making prototype, please stay tuned
Miguel_79
Last seen: 22 min 26 sec ago
Wurkkos Terry wrote:
Mblackes wrote:
Any updates?
It’s great to know that, this flashlight looks spectacular.
Sirstinky
Last seen: 10 hours 24 min ago
Mblackes wrote:
Any updates?
Awesome!
Wurkkos
Wurkkos's picture
Last seen: 4 hours 37 min ago
XHP50.3 Flat LED use in center emitter, seems a good choice Smile
AssortedEnthusiast
Last seen: 2 months 6 days ago
I heard rumors about the XHP50.3 but I didn’t know there would be a flat version. What can expect from this emitter and how would it compare to something like the SFT40?
So far I am loving everything about this prototype and I look forward to it’s release. If I could suggest one thing, it would be to offer SST-20 2700k for the flood emitters. Keep up the awesome work!
rost333
rost333's picture
Last seen: 2 months 4 weeks ago
+1
dthrckt
dthrckt's picture
Last seen: 5 days 17 hours ago
Yes!
Twin8
Twin8's picture
I think its important to at least offer high cri sst20’s in the outer ring. High cri / nicer tint is important in a flood beam, less so in a thrower.
icpart
Last seen: 32 min 47 sec ago
Better will be LH351D 90CRI. It is more floody compared to SST20 and have great choise of colors compared to only 4000K for SST. Also LH351D has better efficiency compared to SST20.
Wurkkos
Wurkkos's picture
we decided use LH351D for flood finally
AssortedEnthusiast
That sounds great!
Miguel_79
Any news about this model?
ArtieT59
ArtieT59's picture
Last seen: 1 hour 54 min ago
Xhp50.3 HI in the center does sound like a great idea!
[FLF] Five Light Friday https://budgetlightforum.com/node/78749
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
The BLF GT with SFT40 (2300lm, 2700m+ @ 30 seconds!)
https://budgetlightforum.com/node/79561
Tatteredmidnight
Last seen: 2 hours 35 min ago
Proper regulation would be a great addition, no more FET direct drive.
Haukkeli
Last seen: 32 min 13 sec ago
So it would be 2S2P battery arrangement if it uses XHP50.3 hi?
kokosnh
any changes of plan, for the dual switch, now that the Anduril tint ramping and instant channel switching firmware is out there (looking at the hank KR4).
tactical_grizzly
tactical_grizzly's picture
Last seen: 13 min 58 sec ago
Those features aren’t new in Anduril. LT1 & K9.3 have had those for quite awhile. Wurkkos knew that, and still decided to forego Anduril and use this dual switch design instrad, unfortunately.
Flashlight enth...
What is the current status of this? Also does anyone have a ballpark guess where the price would be?
JaronRH
Last seen: 3 weeks 21 hours ago
This is sounding like a great light!
LumenMax
LumenMax's picture
Last seen: 13 hours 47 min ago
Wurkkos is still working on the circuit/driver design. No estimated date of completion for this yet.
st0ckmod
Last seen: 1 month 2 days ago
I was just thinking about a light like this. Definitely interested!
Wurkkos Terry
Updated
funwok
Last seen: 3 hours 15 min ago
Do you already know which LED to use in the final product?
Wurkkos Terry
12*LH351D +1*SFT40
Miguel_79
We need more pics of the prototype please.
TopDog
Last seen: 1 month 1 week ago
This is a exciting light concept. Can’t wait to see how it develops in 2022.
