Emisar D3AA is available now
we are very flexible, you can request either anduirl 1 or 2 by sending us an email.
I really appreciate the enthusiasm from reddit users, but for some reason, I’m not able to view Reddit recently, .
DM stanads for D and M series combination.
The price should be $55~75 depends on the versions.
This is prototype, but it’s 95% the same as the final version, the length is 120mm.
If the reaction from Reddit is any indication, you’re going to sell a ton of these lights - especially at that price!
Honestly this seems like it will be a great light for my uses, between the size and the B35 option, I’m very excited to try it out when it becomes available.
Of the emitters you’re offering in this light, do you have a personal favorite?
Hank, are the newly stocked D4Sv2 tint ramping?
They are not, but we do have the tint ramping and independent dual channel version D4S V2 in stock,
you can send us an email for the custom build.
Very exciting! Hank, is there any extra cost when custom ordering with channel switching or ramping (besides the varied cost of different emitter options)?
Any plans to offer an IR option on any lights?
There is no extra cost, we can even add the switch backlight for this new version, just like the D4V2 TI.
YES!! This is very good news indeed! A tint-ramping D4SV2 with a backlit switch is very exciting!
What about the driver? Same one or like in KR4/DT8?
If it has tint ramping then it’s an entirely new driver.
I tint ramping S model with a 26800 tube, please :money_mouth_face:
Hank, what is the output of this new dual channel D4sv2 driver (tint shifting, not ramping)? Is it 9amp CC? is that 9amps per channel ? (meaning 2x leds on channel one get 9amps while ON, and 2x LEDs on channel 2 get 9amp while ON?)
If doing an osram W2 version of new D4sV2, 9amp for 2x led's is fine, but so is FET if proper battery is used (green and white W2 can handle 7.5amps each = 15amps capacity). How should we order, what notes do you need to know?
For the 219B version, it’s 5A per channel.
For the XP-L HI, W1, W2, SST-20, it’s 9A per channel.
They are fully regulated, FET disabled.
What about this new driver in normal D4SV2? Possible or only in new tint-ramping and dual-channel?
Now just release DM11 and people will overload your site :smiley:
Would it be possible to see this driver on D4V2?
is there fet on the driver? Is it just disabled?
Has anyone measured Duv for the sw27 yet?
Can two channels be used simultaneously with a maximum power of 2 * 9A?
No, if the two channels to be used simultaneously, it would be 9A in total.
