If the reaction from Reddit is any indication, you’re going to sell a ton of these lights - especially at that price!
Honestly this seems like it will be a great light for my uses, between the size and the B35 option, I’m very excited to try it out when it becomes available.
Of the emitters you’re offering in this light, do you have a personal favorite?
Very exciting! Hank, is there any extra cost when custom ordering with channel switching or ramping (besides the varied cost of different emitter options)?
Hank, what is the output of this newdual channel D4sv2 driver (tint shifting, not ramping)? Is it 9amp CC? is that 9amps per channel ? (meaning 2x leds on channel one get 9amps while ON, and 2x LEDs on channel 2 get 9amp while ON?)
If doing an osram W2 version of new D4sV2, 9amp for 2x led's is fine, but so is FET if proper battery is used (green and white W2 can handle 7.5amps each = 15amps capacity). How should we order, what notes do you need to know?
What about this new driver in normal D4SV2? Possible or only in new tint-ramping and dual-channel?
Now just release DM11 and people will overload your site
Does this tint ramping D4SV2 use the same driver as K9.3, just with a different firmware? Is K1 now using this same driver as well, again just with a different firmware?
