It’s just disabled.
ArtieT59: Hank Wang: ArtieT59:Hank, what is the output of this new dual channel D4sv2 driver (tint shifting, not ramping)? Is it 9amp CC? is that 9amps per channel ? (meaning 2x leds on channel one get 9amps while ON, and 2x LEDs on channel 2 get 9amp while ON?)
If doing an osram W2 version of new D4sV2, 9amp for 2x led’s is fine, but so is FET if proper battery is used (green and white W2 can handle 7.5amps each = 15amps capacity). How should we order, what notes do you need to know?
For the 219B version, it’s 5A per channel. For the XP-L HI, W1, W2, SST-20, it’s 9A per channel. They are fully regulated, FET disabled.
is there fet on the driver? Is it just disabled?
It’s just disabled.
Does this tint ramping D4SV2 use the same driver as K9.3, just with a different firmware? Is K1 now using this same driver as well, again just with a different firmware?
Hank Wang:For the 219B version, it’s 5A per channel. For the XP-L HI, W1, W2, SST-20, it’s 9A per channel. They are fully regulated, FET disabled.
Would it be possible to see this driver on D4V2?
Not sure about D4V2 since the driver pcb is too small, but we do have the same options for KR4 flashlight, I mean the tint ramping and dual channel versions.
Hmmm...you got my attention!
EDIT: going to wait for DM11 and order both
id30209: Hank Wang:For the 219B version, it’s 5A per channel. For the XP-L HI, W1, W2, SST-20, it’s 9A per channel. They are fully regulated, FET disabled.
How about the DT8?
I am waiting for one and I am so curious
Just to be clear, this tint ramping works like on K9.3, right? It's not like on IF25?
Just to be clear, this tint ramping works like on K9.3, right? It’s not like on IF25?
It’s Anduril 2, so tint ramping works like any other Anduril 2 light: 3H from on (click 3x and hold the last click) and it will slowly ramp between the two emitter types. That’s how the tint-ramping K9.3 works as well.
id30209:Just to be clear, this tint ramping works like on K9.3, right? It’s not like on IF25?
Yes, indeed, K9.3, tint ramping/channel switching D4S V2, and KR4 are with the same driver, only different format.
Tint mixing, rint ramping, channel switching, it could be hard to understand for the users, that is why I have sent 2 pcs D4S V2 to LuxWad for reviewing, hopefully, he will explain the difference better in the video.
I don’t have any of mentioned models so i’m a bit confused how this works. So once you set desired temp it will ramp up and down in that CCT?
EDIT: gonna check some K9.3 videos
Can you specify?
Please make sure firmware is:
-Channel Switching: instantly switches from one channel to the other with no smooth transition
I saw that in one of you posts so I just asked for that in my emails to him!
That was my question exactly… having 2 channels is what puzzels me. Are you using one or both at the same time?
tactical_grizzly: id30209:Just to be clear, this tint ramping works like on K9.3, right? It’s not like on IF25?
Can you specify?
Anduril 2 supports both channel switching (instantly going from one set of LED’s to the other) as well as channel ramping (slowly and smoothly switching from one set of LED’s to the other). Which style of switching depends on which firmware version you use. I don’t think there’s a way to select which style on the light itself so unless you have a reflashing kit, you’ll want to specify which style you want in your order.
Initially, K9.3 only had channel switching, not ramping. I believe Hank recently added the option to have channel ramping if you request it by email.
rjkesler: tactical_grizzly: id30209:Just to be clear, this tint ramping works like on K9.3, right? It’s not like on IF25?
Can you specify?
Exactly!
tactical_grizzly: rjkesler: tactical_grizzly: id30209:Just to be clear, this tint ramping works like on K9.3, right? It’s not like on IF25?
Can you specify?
Exactly!
The man himself… clearing it all up! Thanks, Hank! That’s the last email from me……I hope!
Also, thank you to Tactical Grizzly for pointing all this out. Between you being on here and reddit I’ve adjusted my order a few times!
whoa whoa whoa!! Ok, this is interesting to me now!
tactical_grizzly: rjkesler: tactical_grizzly: id30209:Just to be clear, this tint ramping works like on K9.3, right? It's not like on IF25?
Can you specify? Please make sure firmware is: -Channel Switching: instantly switches from one channel to the other with no smooth transition I saw that in one of you posts so I just asked for that in my emails to him!
Anduril 2 supports both channel switching (instantly going from one set of LED’s to the other) as well as channel ramping (slowly and smoothly switching from one set of LED’s to the other). Which style of switching depends on which firmware version you use. I don’t think there’s a way to select which style on the light itself so unless you have a reflashing kit, you’ll want to specify which style you want in your order. Initially, K9.3 only had channel switching, not ramping. I believe Hank recently added the option to have channel ramping if you request it by email.
Exactly!
Cheers to all!
It's clear now.
Definitely looks like there’s some confusion about these tint-ramping lights, I’ll do my best to make it clear and easy to understand.
There is a lot of interest and excitement for all the new lights you have coming out, everything looks really great! Thanks for the work and for providing information for us here
You better hurry up with that video...
You better hurry up with that video…
Lol, unfortunately all I can gaurantee is that I’ll be less late to the party than normal Hopefully it’ll be quick enough to help some people out though
