Anyone tested this type of 5000mAh 26650 battery (new top design)?
3 posts / 0 new
d_t_a
Last seen: 3 hours 40 min ago
Just got some new 26650 batteries and noticed that they have this top design, which I haven't seen before on 26650 batteries.
Wurkkos "5000mAh" 26650 & Sofirn "5500mAh" 26650
Enook "5000mAh" 26650 & Vapcell purple "5000mAh" 26650
I'm not sure if they are the same battery internally, or just share the same top design.
the bottom look a bit similar (3 of them have a ring indentation, except the Vapcell)
Using YR1030 IR tester, the Enook & Wurkkos have similar IR, and the Vapcell is also nearly similar IR. But the Sofirn has higher IR.
I haven't tested capacity yet (using SkyRC MC3000), but will try to do so sometime.
Anyone have tried these, or maybe know if this is just a new 'top-design' but with previously known batteries, or would they be some new type of 26650 batteries?
raccoon city
raccoon city's picture
Last seen: 53 min 59 sec ago
The new top design looks like some car's hubcap.
texas shooter
Last seen: 9 hours 23 min ago
Also same on the KeepPower IMR 26650 battery 5500mAh 15A I bought last year.
