Thanks Hank. How do I order tint ramping kr4 again. None for D4v2 right?
There is purhcase link on the site, you can order the regular KR4 on the site, and let us know the order number, it will be fine.
Hank, does 2x SST20-DR and 2x 219B-V1 3500K work together both in KR4 and D4SV2? If so, what driver will you be using? 5A noFET or 9A noFET? Are LEDs aligned in diagonally crossed pattern or two colors side by side?
Hank, does 2x SST20-DR and 2× 219B-V1 3500K work together both in KR4 and D4SV2? If so, what driver will you be using? 5A noFET or 9A noFET? Are LEDs aligned in diagonally crossed pattern or two colors side by side?
Yes, this combination works for both KR4 and D4S V2.
There are dozons of different combinations.
We choose the suitable current for each combination.
For example, if you choose 219B on both channels, we will use 5A for each channels.
If you choose 219B on one channel, and W1 LED on the other channel, we will use 5A for 219B, and 9A for W1 LED channel.
If you have your preference, just drop us an email, we will customs make it for you.
Thank you Hank. That is very helpful information. I am just waiting for DM11 to become available before I make my next order for at least two more flashlights.
Hank, I’m wondering about ordering a D4SV2 with the new constant current driver but with 4 identical emitters (no tint ramping). In this configuration, will the maximum output be lower than the standard D4SV2 with the same emitters?
It’s not specifically tint ramping, but actually channel ramping. Your emitter choices determine whether it’s tint ramping, color ramping, hotspot-width-ramping (digital zooming, sort of), or whatever.
If you have emitters with two different color temperatures (like 219B’s in 2700K and 4500K), then the color temperature will ramp. If you have two emitters with different intensities (like W1’s and XPL-HD’s), then the hotspot width will ramp (basically). If you have one set of green emitters and one set of red, then the color of the beam will ramp between green and red with every color in-between.
Good point. Actual tint ramping probably isn’t very useful at all – what people are after is CCT ramping.
What I mean by this is changing the tint or duv (how far above or below the BBL) but keeping the CCT constant.
For example if you wanted to, you could ramp between some rosy 4000K sw40 219B LEDs and some green SST20 LEDs that are also 4000K but why would you?
LEDs are at crossed pattern.
Hank can you use a 7.5A noFET driver to power the 219BT-V1 diodes in the D4S V2 flashlight?
The question is about the D4S V2 in the two channel “channel ramping” version (2× 219B 2700K 7.5A and 2x XP-L HI 4000K 9A).
5A for two 219B diodes is a very delicate current. I would prefer 7.5A.
7.5A / 2 = 3.75A per diode
One 219BT-V1 diode can operate stably up to 4A. http://i.imgur.com/bkodESs.jpg
Another question is about the flashlight in a different configuration:
More and more people want to buy an Emisar D4Sv2 flashlight with four Osram W1 LEDs with a single channel driver with full stabilization and with an unlocked FET for Turbo as it is in the KR4 flashlight (9A Constant Current + Direct Drive). Hank are you able to prepare such a driver for D4S V2?
I see that user “CollectEverything” is also asking for the same configuration.
The D4SV2 with 4 Osram W1 LEDs is offered with an outdated driver (FET+ 3). I think many people would gladly buy a D4Sv2 flashlight with 4 Osram W1, W2 or XPL HI diodes if it had a driver like the KR4 has (9A CC + DD), because such a driver would give very good high brightness stabilization.
Hi,
I’m planning to order D4v2. Is there a samsung leds options for this flashlight via sugestions?
(If yes, any post or information about it such as numbers of flashlights max and continuous outputs.)
I’ve been holding out for a 21700 single emitter w/ Anduril2 and – most importantly – a buck/boost driver for so long. I have a D4v2 (5A driver) but never use it because it can’t sustain the output I need. Was about to give up again and order a ZL SC700d. (And/or a KR1 and mod it with theFreeman’s or Loneocean’s drivers.) Can’t wait to order a DM11.
I know it would be absurdly heavy, but I’d get it in brass black. I’d actually get a K1 in brass black if it would take the DM11 driver. I’d have to lug it around for miles in the desert but it’s worth it for copper/brass.
Anyway, can we request the DM11’s driver in the K1? Will the D4V2 or KR1 get the new buck drivers?
There has been no mention of buck drivers in any of Hank’s lights (including DM11) as far as I can tell.
it will be fine.
https://intl-outdoor.com, Noctigon, Emisar, flashlight components.
Any chance of it happening in a D4v2 or too small?
By the time waiting for DM11, my bad habit made me click the buy button for Kr4 tint shift verssion. Thanks Hank, waiting for it …
Only Hanklights
My Collection
DavesTechReviews.com / Big list of Luminus SBT90.2 flashlights / Mega throwers and flooders / Anduril Thermal Calibration Config / Converting Candela to Throw / My reviews on 1lumen (managed by ChibiM, not me)
Email:
<my BLF username>@gmail.com
D4SV2 – Cree XPL-HD 5000K/Osram CSLNM1.TG 6000K
https://www.youtube.com/luxwad < Videos
Hi, your request is fine, please send us an email, contact@intl-outdoor.com
Hank is possible to let us know the current you use for each emitter?
1) SST20
2) XP-L HI
3) 219b
4) W1
5) W2
6) LH351D
Sure, apart from the 219B LED which is 5A per channel.
Other LEDs are all 9A per channel.
Hank thanks for your reply.
Picture of my flashlights for attention
Omg, this is awesome, does this do tint ramping or channel swap? Or both?
Very nice setup for max output
That one does just channel swap.
This one is Nichia SW27/SW45k, and ramps between the two.
This Video shows both in action. I will be doing a more detailed video on my channel soon.
Also, lighted switches! Thanks Hank for making and sending these awesome lights
Hank, will it be possible to put this new driver from KR4 in DT8? I saw noone asked about that.
Also SBT90.2 in DM11 possible?
Keys: Flashlight S11 MOD, Lumintop GT Nano, Astrolux LT1, Astrolux K2, Manker E02 II, Manker E03H II
Full: Jetbeam RRT01 XP-L HI, Fireflies PL47MU, Fireflies PL47G2 2021 XP-L HI, Emisar D4V2TI RO1 XP-L HI, D4V2TI RO2, XP-L HI Emisar DT8 XP-L HI, Emisar D4V2 LH351D+W1, Emisar D4SV2 LH351D+W1, Noctigon KR4 XP-L HI+Nichia, Noctigon KR1 SBT90.2, Noctigon DM11 SFT40, Lumintop ODL20C V2, Fireflies E07 XP-L HI, Fireflies E07 2021 XP-L HI, Armytek Wizard Pro Max WW, Emisar D18 X-PL HI, Noctigon K9.3, Niwalker ES2 (lot of modules), Weeltool W4, Fenix LR40R modded XP-L HI tint mix+W2, BLF LT1 v6, WildTrail WT90, Amutorch DM70 4000K, Imalent MS18W
Eta on when black will be back in stock for d18?
Hi,
Thank you!
Hank,
I’ve heard rumors that you are working on a 26800 body tube for D4SV2. Is this true? If so, do you have an estimated release date?
Are you working on 26800 tubes for any other lights, like K1 or K9.3? I believe a 26mm cell would fit.
Reddit | Grizzly’s Reviews | YouTube | Convoy Guide
Do we know when theDM11 comes out yet? Anyone already have any experience with the Nichia B35?
According to this Reddit post it’ll be released “next month” (November) and there will be a pocket clip available.
Yes, that is true, the 26800 tube should be available by November.
There are no other 26800 project plans.
I think I might be getting a dm11 b35. Looking forward to seeing final specs and finishes. Curious how it’ll compare to a d4s 26800 with sst20s.
https://fundrazr.com/osturaband
No affiliation, just a fan.
Thanks!
I have plenty of B35AM and B35AR and so far they are my number 1 emitter in both 90+CRI and output ( 1500+lumens).
They are big bro's of 219B and E17/21.
WTB Titanium 4sevens 2xAA tube
