The P15 EDC Tactical Flashlight in domestic and foreign won praise of users since its listing. P15 rechargeable LED flashlight has a compact build for easy grip and portability. The light can produce a maximum output of 1700 lumens and long-range beam up to 330 meters.The White/LightGray/Gray anodization looks really white and exquisite!
_
Updated:
The Acebeam P15 is sold in two configurations, as an EDC light and as a tactical rail-mounted light. Compact size, six unique lighting modes, and single handed operation, convenient for everyday carry on walks, camping trips, or for use during a power outage. The P15 Tactical Light directly addresses this challenge – moving between a back clip with removal or addition of two screws to Picatinny and MLOK mounting options.
ACEBEAM P15 is a brand new versatile flashlight for both EDC and tactical use. Fitted with the planar LED, compact size, exquisite appearance, make it performance breakthrough while keeping the same size. P15 is work with M-Lok, compatible with PICATINNY, Tactical Ring (Optional) for offering more convenient carrying and flexible operating ways. Original design for fast operating charging,remote control, tactical operations and one-touch-strobe by rotating the toggle lock. P15 is a reliable and high-performance lighting tool for professional users in any harsh situation.
I don’t see a way to integrate usb c while maintaining the locking and multi switch functions in a single connector, so the proprietary design actually makes sense.
You need to look at this from a consumer’s perspective (like a law enforcement officer, military). They don’t care about proprietary batteries and charging. This is meant to go on a weapon and light up targets or as a duty light, not take on a walk at night. It’s purpose built. Proprietary batteries are a safety feature and ensures lights meet factory specs. Yah, annoying for an enthusiast, but most buyers won’t care.
Clip design is a bit strange. Clearly designed more for looks rather than function.
It appears to be a VERY long clip. Except that the useful portion of the clip is only the bottom half. Result is a clip that looks like it ought to be deep carry, but is anything but.
The decorative bit sticking out from the back of the clip near the switch looks like it would get caught on things if the light is carried inside a pocket. This detracts from its ability to be quickly removed from a pocket.
This is primarily a WML that can be pocket carried. The clip is sort of a dual-purpose M-LOK/Picatinny mounting solution. Again, I have a couple Odins and they are mainly for weapon duty with the added benefit you can pocket carry them.
Acebeam New P15 is an innovative work in the EDC tactical field, which can quickly switch between EDC and tactical light.
Remove the back clip and mount with Pic Mount or MLOK to become the tactical light.
Multi-functional port is compatible with charging battery, installing the remote tail switch control or One-Touch-Strobe switch.
Learn more: Acebeam Unique and Innovative New Lighting Tools
Acebeam’s other lights aimed at a similar market (L series, T36, EC35 II) use a double-wall battery tube with a leaf spring on each end. While some double-wall designs like the FW3A haven’t been entirely reliable, Acebeam’s approach has worked great.
I only own 2 Acebeam lights, and I’ve never taken either of them apart. What’s their general stance on potting? Does anybody know if the P15 is potted, or otherwise sturdy and shock resistant?
