Hank is possible to let us know the current you use for each emitter?
1) SST20
2) XP-L HI
3) 219b
4) W1
5) W2
6) LH351D
1) SST20
2) XP-L HI
3) 219b
4) W1
5) W2
6) LH351D
Sure, apart from the 219B LED which is 5A per channel.
Other LEDs are all 9A per channel.
Hank thanks for your reply.
Another question is about the flashlight in a different configuration:
More and more people want to buy an Emisar D4Sv2 flashlight with four Osram W1 LEDs with a single channel driver with full stabilization and with an unlocked FET for Turbo as it is in the KR4 flashlight (9A Constant Current + Direct Drive). Hank are you able to prepare such a driver for D4S V2?
I see that user “CollectEverything” is also asking for the same configuration.
The D4SV2 with 4 Osram W1 LEDs is offered with an outdated driver (FET+ 3). I think many people would gladly buy a D4Sv2 flashlight with 4 Osram W1, W2 or XPL HI diodes if it had a driver like the KR4 has (9A CC + DD), because such a driver would give very good high brightness stabilization.
Hi, please send us an email for the request.
Omg, this is awesome, does this do tint ramping or channel swap? Or both?
Very nice setup for max output
That one does just channel swap.
This one is Nichia SW27/SW45k, and ramps between the two.
This Video shows both in action. I will be doing a more detailed video on my channel soon.
Also, lighted switches! Thanks Hank for making and sending these awesome lights
Hank, will it be possible to put this new driver from KR4 in DT8? I saw noone asked about that.
Also SBT90.2 in DM11 possible?
Eta on when black will be back in stock for d18?
Hi,
I’m planning to order D4v2. Is there a samsung leds options for this flashlight via sugestions?
(If yes, any post or information about it such as numbers of flashlights max and continuous outputs.)
Thank you!
Hank,
I’ve heard rumors that you are working on a 26800 body tube for D4SV2. Is this true? If so, do you have an estimated release date?
Are you working on 26800 tubes for any other lights, like K1 or K9.3? I believe a 26mm cell would fit.
I’ve been holding out for a 21700 single emitter w/ Anduril2 and - most importantly - a buck/boost driver for so long. I have a D4v2 (5A driver) but never use it because it can’t sustain the output I need. Was about to give up again and order a ZL SC700d. (And/or a KR1 and mod it with theFreeman’s or Loneocean’s drivers.) Can’t wait to order a DM11.
I know it would be absurdly heavy, but I’d get it in brass black. I’d actually get a K1 in brass black if it would take the DM11 driver. I’d have to lug it around for miles in the desert but it’s worth it for copper/brass.
Anyway, can we request the DM11’s driver in the K1? Will the D4V2 or KR1 get the new buck drivers?
There has been no mention of buck drivers in any of Hank’s lights (including DM11) as far as I can tell.
Do we know when theDM11 comes out yet? Anyone already have any experience with the Nichia B35?
According to this Reddit post it’ll be released “next month” (November) and there will be a pocket clip available.
Yes, that is true, the 26800 tube should be available by November.
There are no other 26800 project plans.
I think I might be getting a dm11 b35. Looking forward to seeing final specs and finishes. Curious how it’ll compare to a d4s 26800 with sst20s.
Thanks!
I have plenty of B35AM and B35AR and so far they are my number 1 emitter in both 90+CRI and output ( 1500+lumens).
They are big bro's of 219B and E17/21.
Do you plan on offering 28600 cells (QB26800) with this tube ?
I found one seller (with not so good ratings) on AE but it’s quite expensive and 2 months shipping.
There is one US seller but international shipping is expensive.
Will there be a option to order the new leds(B35AM and SFT-40) when you release the DM11? How much would the shipping costs?
