Ordered (polished titanium)
Thank you!
I will check if they are able to provide. If anyone is interested in 14500 conversion or bundle, do express your interest in this thread by the next month.
I’m interested in getting one. Thank you.
I’m also interested in the extension tube if they decide to make one.
Ordered a Ti Damascus. First Damascus light I'll own, just looks so good... Hope it holds up.
I got a couple cheapo twisties about the same size, same domed cap and a lot around the house. This one has sooo many features, should be interesting.
Thanks freeme!
Years ago i started designing a light like this as a safety light for fishermen but got over it, at the time it was to hard i couldn’t find a driver that could run a RGB and normal LED from the same switch, i did want it to run on a AA or AAA. A small beacon light like this could save peoples lives when rock fishing as long as its robust enough to survive a dunking.
Can i have the code please?
Rating of this LT1 is IP65, so can't survive a dunking, but rain, splashing is ok. I'd suspect the switch - doesn't look so good for immersion in water. The threaded tube and optic should be o-ring protected at least.
Rating of this LT1 is IP65, so can’t survive a dunking, but rain, splashing is ok. I’d suspect the switch - doesn’t look so good for immersion in water. The threaded tube and optic should be o-ring protected at least.
Usually get issues with the charging port covers after a bit of time and use, it would be great to have a fully sealed version of this light.
Ohh, yea, didn't notice the outside USB-C cover...
Purchased … Stonewashed Ti.
Many Thanks.
What a creative name! Wonder how they came up with that.
Thanks got 2.
I wonder what it means? I’m sure I’ve never heard of anything like it, let alone for another lantern in the enthusiast flashlight world.
Interested in 14500 conversion Tube.
Picked a polished Ti and would like a 14500 tube also
Interested.
Okay.
Interested.
Please give me a code
Mine is at the post office, should come Monday.
:THUMBS-UP:
Received it - Ti Damascus finish. Interesting light, bright out of the box, battery as-is. UI is described on the back of the plastic case - no manual. Undocumented is 1H to turn OFF the light when in RGB mode.
The BG listing page has a more accurate, complete description of the UI. Only thing different is the solid RED is more like pink, while the breathing RED is more a true RED.
Switch is stiff but should prevent accidental turn on's. It's got LVP and temp control, so they say on the package -- didn't test it.
The damascus finish looks pretty good.
Nyogel helped on the o-ring, and threads. Battery came charged > 4.03V. I see these 3.7V batteries sold, only in volume though right now on Ali.
