I can test this sometime but in theory the bottleneck of the thermal pad should be apparent on very short timescales. Longer tests basically should show the difference of the thermal path further away from the led.
Heat starts at the LED junction then goes through: Die > Substrate > Solder > MCPCB > TIM > Heatsink > Air. Anything after the MCPCB should not have an impact in any difference between the two packages. My strategy for testing this would be to actually float the MCPCB in air and do an output test that way at saturation temps. The only thing I can see making a difference at longer timescales is the loss of the thermal ‘driving force’, i.e. the delta Tj and Tmcpcb.
The tests that I do though are pretty aligned with real-world use though. Always open for debate, but let’s do that in another thread maybe :+1:
I’m planning to order S2+ with LH351D (5000K or lower) or maybe SST40…
My question is, what is the different between “Ar-coated glass lens, Smooth” vs “Glass, Orange peel” lens.
I have a flashlight with TIR optic and I really like it. Shall I get also some TIR optics? Is it hard to change by myself?
(Also there are 4 different option type on Convoy store. Bead, flat, matte and striped with several degree)
Thank you so much!
Any suggestions will be a big help
I’ve created a new post here with some of my thoughts on how Convoy’s user interfaces can be improved. I would love for the rest of the community to take a look and tell me what you think, and I also hope Simon will take a look and see if any of these improvements are feasible.
I installed my sft70 LED in the s21b xhp50.2 light and it worked fine on mode 1-3, turned blue on mode 4 (100% output).
I then installed the SFT70 into my m21e and it worked up until about 75% ramp, then turned blue and the light started smoking. I thought i blue the sft70..
But now my m21e wont turn on with the xhp70 in it either. I put that back in and it wont work.
Can i buy just the driver for the m21e from you?
does anyone know what i did to my driver? i wouldve thought that just the led would burn out if anything, and i was completely OK with doing that for the sake of expirementing.. I didnt think it would ruin the driver..
I got my AA/14500 13 group drivers, I also got an orange T3 with an SW35. The stainless screw on clip is way better than the stock clip.
The wires on the 14500 driver are backwards. The red is negative and the black is positive. All three were this way.
Unfortunately I broke one of the drivers tightening the retaining ring in my Jaxman E3. The pliers slipped and broke some stuff off the back of the board. Double sided drivers may be unavoidable, but they are annoying.
I also put one into a Thorfire TG06, It works perfectly in that light as well. It’s also sold as the Alonefire X380. Same host with slightly different reflector.
I see that S12 UV’s product listing now says 2.4A maximum where it used to say 6A before, if I remember correctly. Does it come with a different driver now?
