Depending on the type of TIR, a glass lens can really ding the overall efficiency of the optics.
I wonder if the rise in current is from the emitter heating up and Vf dropping. That’s usually not accompanied by rising output, but i suppose the change is subtle enough to be explained that way
Well, I got a FF E01 w/SST-40 (not an EA01), but the TIR optic is different - you can see the LED, but the other differences like the smaller width optic in the E01, and SST-40 vs. SFT-40 has big differences in throw.
I thought I remembered you having an ea01 or the mateminco equivalent… my bad.
I’ve been wondering how the FF might do with the SFT… how close to 100kcd it could hit. My assumption is 220% throw vs an old bin sst40. It oughta be much more pocketable than the if22a.
Could it be possible that as the battery heated up, that the battery's internal resistance decreased allowing a slightly higher voltage to deliver a little more current and increase the brightness before the voltage sag eventually caused the brightness to decrease?
Ohh - tried the MT01 TIR optic in the IF22A and got 124 kcd, though the beam looks different, most would probably say worse - larger hotspot but a bright spot in the center of the hot spot. The optics appear to be designed differently in the center. The IF22A has a larger diffused spot in the optic.
MT01 w/IF22A optic: 73 kcd - beam looks softer, hot spot not as well defined.
(same 5 sec delay, at 5 meters, same cells as-is, not re-charged)
Thanks Tom. I was interested in the differences between the two larger optics… basically the question if they are identical or not… and what the throw ratio was stepping down to the E01. It’s a rare light and not many reviews or posts talk about it, so I wanted a head to head comparison. So thank you!
What this suggests, thanks to your extra testing with swapping the optics around, is that we can expect mid-high 70s kcd for the E01 with an SFT40. I think this is a sweet spot of sorts for maximum throw while staying quite pocketable. Above 34mm head really isn’t comfortable, at least for me as a slender person who wears Levi 511’s. YMMV
+1 for 5000K
any word of these being available? i’m looking to switch from my C8+ (XPL HI U6-4C 4200-4500K) which i do love, to a 21700 thrower with internal charging.
come on sofirn! i love my IF22A for close work, as well as my LT1 :+1:
do folks hate the font, or where it comes from? i actually like the way the font looks. easy to read. don’t care for the source though. :smiling_imp: :person_facepalming:
I noticed the other day that Sofirn has released the IF22A in colors. Green, red, and purple. Available on ali. On Amazon US I see they put placeholders but they aren’t available for sale there yet.
