i don't have the original xhp35 HI version, but I have to imagine this is similar but throws further.. I think? It lights things up in the foreground too. It's amazing lol, I'll how it in beamshots, been raining for 2 nights here now of course.
I measure throw from 7 meters normally, but have the option for 12.5 meters. My original GT did not measure more than a few percent different for those two distances (can’t remember the exact numbers). So I expect that 5 meter will get close enough numbers too.
Okay… I was thrown off here by the format Artie used. 1803kcd or 1.8Mcd back calculated from 5m. The way I read it I thought there was a units typo and it was 1803lux @ x meters, which obviously would have to be ten for 2686m of throw. Sorry gents, carry on.
Dunno - maybe because it's a lot of material to ream to convert it. Actually all the stock black centering pieces had holes too big. The one I reamed for the SFT-40 was the best fit one by far. The good thing about the stock piece is it seems to center nicely aligned to the screws. The screws actually down hold anything down. I probably should have put a little dab of silicon glue on the threads to hold them in place.
Actually I got both - A K40, resistor tweaked w/dedomed XM-L2 and a TN31, think resistor tweaked, with a stock domed XM-L2. I think the TN31 is under-performing even for a dome XM-L2, but the K40 does ok but never does as well as a TN31. The thing is I'm thinking I'm not going to be able to get more amps out of those lights, and not sure what amps they put out right now. I'd have to carefully test the amps before even attempting an SFT-40, since they are sensitive, as I'm finding out. Burnt 2 of them out yesterday in a modded 3X221A.
All depends on the amps. If I can get only 6 to 7 amps, then results would be so-so. If those lights can do 8-9 amps, now we are talk'n, but 10+ amps -- watch out! I'm hoping the way the modded driver works, the amps will be the same disregarding the LED Vf, but maybe that's not true - maybe I'll get more amps with a SFT-40 running at a lower Vf. Not sure how it works.
All depends if the amps are the same, how a dedomed XM-L2 compares with a SFT-40.
