FREEME ✌ ASTROLUX WP3 LEP 562lm 2952m 21700 Flashlight Group Buy
Estimated shipping date will be around November 15.
Has anybody found a suitable holster/case for the WP3 at all?
How about FT03 holster?
I’m pretty sure it wouldn’t fit. Although I might get one anyway to try, and use it for my FT03 if it doesn’t work.
FT03 = length - 170mm, head diameter - 69.5mm
WP3 = length - 184mm, head diameter - 59.5mm
Holster has room for extra 14mm but it will be tight fit though.
ASTROLUX WP2 185mm
I’ll give it a try, thanks Freeme
Interested in code, too!
Just received mine and it is a crazy thrower. Just curious if anyone has tried the 26650 battery in it yet. As you know it comes with a 21700 battery and various reviews indicate that a 26650 battery will work as well. However the owner’s manual makes no mention of the 26650 battery only the 21700.
Used a 26700 and it worked fine as far as I can tell; not that I use the light much as I don’t want to frighten the good citizens of the neighborhood.
Any recomended 26650 battery?
Thanks in advance
VapCell INR 26650 5500mah 20A (2021)
https://www.aliexpress.com/item/1005002424304589.html or similar 26650 with 15A?
Hi Freeme. Please send code. Thanks.
You got mail!
Ordered. Thanks for the code freeme! :beer:
This is going to be my first LEP and I simply can not wait for it to arrive!
My current longest throwing torch is the Convoy L21a CULPM1.TG.
You won’t be disappointed. It still makes me laugh every time I turn it on!
Thanks TMaxxJJ.
I’ve actually got a real use case for it. I really enjoy stargazing with friends. Until now I used a laser to pint out stars, but lasers have two problems for me.
1. They really are very unsafe to use without proper eye protection.
2. I usually have to make sure that there are no aircraft flying in the same direction as where I point the laser.
Hopefully an LEP will solve both problems.
Don’t get me wrong, I bought it mostly for fun. However, it will also serve a real purpose.
LEP is definitely in a league of its own.
interested
Interested
order placed, got Astrolux Upgraded A02 SST20 as a gift
Any recommendation for diffuser that can be open? I heard that the diffuser for the Weltool W4 will fit it with an o'ring, but is there something better for it, that will just fit?
