13762 posts / 0 new
sp5it
sp5it's picture
Last seen: 2 hours 30 min ago
Can I put 4xE21A on Noctigon into my FW3A?
Mike
Think of how stupid the average person is, and realize half of them are stupider than that. George Carlin
 Anyone offended by my signature please fill Complaint Form. Thank you.
 If a lot of people listen to Slayer, the world would be a better place to live" - Tommy Wiseau
JaredM
JaredM's picture
Last seen: 8 min 2 sec ago
FET will need to be disabled
https://fundrazr.com/osturaband
No affiliation, just a fan.
sp5it
sp5it's picture
Thanks.
Firelight2
Firelight2's picture
Last seen: 4 hours 27 min ago
Mike
Also the FW3A is sized for 20mm triple stars. If you want put a 24mm quad star inside you will need to file down the edge of the star and optic.
JaredM
JaredM's picture
Centrally grouped “quadrix” arrays could work. I ran a 3500+4500k mix of e17s in my fw1a for a under a frosted ledil leila. Beautiful beam, but the emitters kept getting damaged. Those little things are DELICATE.
Firelight2
That can work, but the FW3A is designed for Carclo optics and only has 7mm of clearance between the star and the lens.
I suppose you could buy a stainless steel FW1A bezel if they are available. Maybe you could convert an FW3A into an FW1A this way. If you can source an appropriate reflector.
Scallywag
Scallywag's picture
Last seen: 5 hours 43 min ago
I suppose you could buy a stainless steel FW1A bezel if they are available. Maybe you could convert and FW3A into an FW1A this way. If you can source an appropriate reflector.
FW1A vs FW3A have holes drilled through the shelf in different places for led wires.
Firelight2
Oh yeah.
But fortunately that’s easy to fix. Aluminum is quite soft and drills easily with any hand drill.
MascaratumB
MascaratumB's picture
Last seen: 33 min 18 sec ago
I’ve turned my FW1A into a kind of “mule” light but with a lens from a cheappo zoomie flashlight.
I am not using a reflector and I am actually using the FW3A bezel instead of the FW1A (the FW3A’s is shorter so it makes pressure and keeps the lens in place.
The beam is completely round, without hotspot in the center, and it quite nice for close/mid range (max. 30 – 40 m, as it looses throw). I have a Luxeon V2 4000K there, so it is a nice tint although not High CRI.
Something like this, but warmer:
Maybe those “quadtrix” LEDs could be used in the same way Wink
stephenk
stephenk's picture
Last seen: 3 hours 9 min ago
ToyKeeper wrote:
d_t_a wrote:
It would appear that Lumintop has been using varying versions of Anduril firmware, and some are probably “modded” due to weird version check.
For instance, I’ve also note a new HL3A that comes with Anduril 2, with the same firmware 2021-01-25 model 322 (so they use the GT Mini firmware for the HL3A with triple-LED?)
I recently ordered a GT Mini with Osram NM1 LED variant, which came with Anduril (the former GT Mini with XPL-Hi uses NarsilM), but when I tried doing 15-clicks-from-off version check, it blinks out 1969-07-20.
At first, I thought this “1969-07-20” may just be an incorrect flash… but later on I asked someone who got a Lumintop GT3 (3x XHP70.2) with Anduril to do a version check, and it also blinks out 1969-07-20. (earlier GT3 used NarsilM, but later GT3 appears to have switched to this 1969-07-20 Anduril version)
I don’t see any firmware with “1969-07-20”, so my guess is (Lumintop?) may have modded the firmware but the date code was some bogus date..
To summarize:
so the new FW3A now comes with Anduril 2, firmware version 2021-01-25 model 322.
the new HL3A also comes with Anduril 2, firmware version 2021-01-25 model 322
GT Mini (Osram NM1) comes with Anduril 1, firmware version “1969-07-20”
later GT3 comes with Anduril 1, firmware version “1969-07-20”
That build date means they (or someone) compiled the sources themselves and didn’t use the build script. It also means they’re probably violating the license.
It’s a value I put into the default code to catch cases like this where someone built it incorrectly. It’s like how a debug version of a program will fill RAM with a value of “DEADBEEF“, because it stands out in a debugger and clearly indicates when a variable hasn’t been initialized properly.
Here’s the version.h file before it gets overridden by the build script:
// this file is replaced automatically by the build script
// set your own date here if you're not using the build script
// otherwise, default to first human contact with the moon
#define VERSION_NUMBER "19690720"
But instead of first human contact with the moon, it’s first Lumintop contact with the code.
If you ever see this date in a production light, it means someone screwed up. Like, someone at that company made a noob mistake. And if they made that mistake, it’s probably not the only one.
Have Lumintop been made aware of our distaste towards their changes to the driver and reflector in the FW1A?
Gunga
Gunga's picture
Last seen: 2 hours 8 min ago
I’ve made an FW1A out of an FW3A. Definitely possible.
JaredM
JaredM's picture
https://budgetlightforum.com/node/67060
I converted my triple to a single 2+ yrs ago. I’ve gone through many configurations over the years. First was a custom, intermediate length bezel made for using an S21A reflector, then later an odd 20mm TIR. After this, I bought a SS bezel from Neal and have been using Ledil Leila optics. First with sliced SST20w, then the Nichias, and I’ve been back to a domed SST20 4000K. Pretty happy with the current setup. 22kcd with an ~11 degree spot and 95CRI. 8kcd runs indefinitely without hardly getting warm.
sergx
Last seen: 1 month 3 days ago
Hello guys! I got my warm crees on mcpcb from kaidomain and also found soldering kit. Seems like now I’m ready to swap mcpcb on my fw3a coz it is impossible to find version with warm cree on internet right now.
But could anybody please give me some advice about this process? How can I disassemble a flashlight and not break anything the first time?
do I need to unscrew the driver from the side of the spring using two holes along the edges? Or I can just pull out mcpcb using the holes for fixing the optics? How tight is it there?
Thank you!
MascaratumB
Thank you!
Modding the FW3A LEDs is easy, you don’t have to mess with the driver, you only need to access the LEDs board from the top (removing the bezel, lens and optic) and then you’ll see the wires that you need to unsolder.
Make sure you don’t have a battery inside to avoid accidental short-cuts in case you touch both wires.
Good luck Wink
JaredM
JaredM's picture
MascaratumB wrote:
Make sure you don’t have a battery inside to avoid accidental short-circuits in case you touch both wires.
Good luck Wink
This!!
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 43 min ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
I’m not sure. I haven’t been in touch with Neal since 2019, and never successfully got in touch with Lumintop directly.
LiteNoob®
LiteNoob®'s picture
Got my FW3A 9 days ago , but the UI is kinda confusing. It does not line up with the original post, with the temperature blinky being after the BattCheck. Had a look at the generic Andúril UI but still can’t set thermal limit as the light does not do the “two blinks”.
Am I doing something wrong? I just do 7H from TempCheck then wait for the first blink, then enter the current temperature. The light then just stops flickering and goes to blinking the now calibrated temperature.
Have I made a mistake in getting an “Inferior” light?
(Edit): I bought from Lumintop’s official AliExpress store.
(Edit 2): Should clarify that I have firmware 322
JaredM
JaredM's picture
What color is the driver pcb inside the head? Purple or red?
LiteNoob®
LiteNoob®'s picture
JaredM wrote:
What color it’s the driver pcb inside the head? Purple or red?
Red Sad (20201226) and a Golisi S26 for the battery
Rayoui
Rayoui's picture
Last seen: 2 hours 29 min ago
To set the thermal limit you must enter TempCheck and do 7H and keep holding the button for the second blink and then let go. The first blink is for setting the current temp.
LiteNoob®
LiteNoob®'s picture
Thanks for the tip! Have I just not read the manual right?
(Edit): Yes. It didn’t make sense to me
Rayoui
Rayoui's picture
Anduril 1 worked as you said, where after entering the current temp the menu would then enter into temp limit setting.
Anduril 2 was changed to make it quicker to get to the specific menu item you are looking for, but it can be confusing if you haven’t used Anduril 2’s menu style before.
LiteNoob®
LiteNoob®'s picture
FW3A with Philips diffuser
FW3A with a diffuser from a Philips LED lightbulb on a custom 3D printed mount.
LiteNoob®
LiteNoob®'s picture
I don’t know what I did but now there is a weird flicker pattern when I ramp the light and I cannot reach full brightness. 13H does not work for reset.
https://youtu.be/9rfa3dmaavA
LiteNoob®
LiteNoob®'s picture
Pretty sure its a software problem. Double click is dimmer then top of ramp for some reason…
LiteNoob®
LiteNoob®'s picture
Update: for any who experience this issue disabling memory timer (which I had likely accidentally enabled) worked to fix the problem.
sergx
Hello! After a long study of the subject, I decided on my first flashlight.
I managed to find an old batch fw3a in polished titanium case (with the original 7+1 driver) (I know that all new models get worse with each batch), also I got mcpcb with nice yellow hi cri leds which I like and swap it by myself.
All this backstory just you to understand how much it hurts me now that my only and long-awaited flashlight is lying in a box for three+ months with couple of 18350 battereis. I like short version and all this time I’m looking for 18350 polished Ti tube for it. Every couple of weeks I send messages to official lumintop ailexpress shop but they answer me the same – “production time is 2-3 weeks”. As I see it is impossible to buy it anywhere online.
So the question is maybe some of you guys have this part and do not use it or know where else I can look for it?
beam0
beam0's picture
Last seen: 4 hours 46 min ago
sergx wrote:
Hello! After a long study of the subject, I decided on my first flashlight. I managed to find an old batch fw3a in polished titanium case (with the original 7+1 driver) (I know that all new models get worse with each batch), also I got mcpcb with nice yellow hi cri leds which I like and swap it by myself. All this backstory just you to understand how much it hurts me now that my only and long-awaited flashlight is lying in a box for three+ months with couple of 18350 battereis. I like short version and all this time I’m looking for 18350 polished Ti tube for it. Every couple of weeks I send messages to official lumintop ailexpress shop but they answer me the same – “production time is 2-3 weeks”. As I see it is impossible to buy it anywhere online. So the question is maybe some of you guys have this part and do not use it or know where else I can look for it?
FW3A18350 polished Ti tube
https://www.illumn.com/flashlights/lumintop/accessories/lumintop-fw1a-fw...
beam0
beam0's picture
After about 3 years, I finally received a new FW3A in army green. I was on the original interest list but due to various reasons including a long hiatus from the hobby I never followed through on buying one until now.
Seeing how AWESOME this flashlight is I regret not getting one sooner, It’s quickly became my favorite pocket light! Nice buttery smooth action of the tail switch but seeing how it’s even more prone to accidental on than even a side switch I’m getting used to using electronic lockout…I love how low modes are usable in lockout! Never had Anduril in a small pocket light before and didn’t even realize it had this feature.
So now I’ve been “FW Bitten” and already ordered an FWAA and an FW1A Pro (XHP50.2) Also considering an FW21 Pro (3xXHP50.2) and X9L (SBT90.2).
However I’m saddened about Lumintop even further downgrading these lights. Fortunately the FW3A I received appears to have been older stock, it has the purple? color driver board with 6 chips like the one on the left in the new OP photo.
I’m now concerned if I’ll get a downgraded FW1A Pro, although maybe the Pro model isn’t affected since it’s a newer version to begin with? I ordered it from “A Lighting Store” on aliexpress, it showed the last one in stock, so maybe it’s an older version.
In the 2021 update post photo I see the downgraded red color board (on the right) is marked FW1A V1.1, does the downgraded FW3A board also look the same with no chips showing? Or are they using that FW1A V1.1 board in the downgraded FW3A?
sergx
Thanks but no. They have no it. Btw this guys have old versions of fw3a with original firmware and 7+1 driver. I ordered mine fw3ti there.
I checked lumintops aliexpress, ebay, amazon, lumintoplighting, lumintoponline.com, jlhawaii808, jc customs, illumn.com, nealsgadgets everywhere it is out of stock. Thats why I’m asking it here and on reddit. Sad
