Thanks again, much appreciated. I feel much happier about it now. The flashlight runs Anduril and this can measure the battery voltage so I will check this periodically once the battery has drained to ensure it’s not dropping below 2.5v
then it definitely has LVP… you need not worry, it is not necessary to use protected cells
the Anduril battery level indicator is also very useful… you have a light with an excellent battery safety feature set. The UI also incorporates thermal step down… another good thing…
some charging voltage tips
LiIon like to be recharged when they are about half empty… any time they go below 3.7V
you can go lower, down to 3.0V, if necessary at the time… but deep discharge does not actually help a LiIon battery…
the LVP will probably shut the light off when voltage drops below 2.7v…
about the battery meter in Anduril… it may be slightly off, by maybe 0.1v too high or too low, compared to a standalone DMM (Digital Multi Meter)…
The Anduril battery voltage display can be calibrated more closely if desired
Just noticed something on my Anduril light with a protected cell and then put an unprotected 30q in and got a similar result. Saw this a time or two and thought it was a glitch. Now it seems consistent and am wondering if anyone can explain it. Here is what happened:
With the protected cell in the light I did a voltage check and got 3.9. Then I ran it on turbo for 30 seconds and ran a voltage check again. This time the voltage read 3.2 on the first pass and 3.9 on the second pass. Put an unprotected 30q in and did a voltage check and got 4.1. Ran it on turbo for 30 seconds and the voltage check gave me 3.4 on the first pass and 4.1 on the second pass. After writing that, with the 30q still in the light, I ran it on turbo for 30 seconds again. This time I took the battery out and put my meter on it and got 4.0 something settling on about 4.08. The number 3 did not come up on the meter at all. Put the battery back in the light and got 4.1.
Running on turbo puts a high current load on the cell which causes the cell voltage to drop as it gets pulled down; when you release the load you will get a bounce-back in the voltage as the cell recovers. This is a normal condition in a good cell. It happens fairly rapidly so you wouldn’t be able to remove the cell quick enough to see the droop on the DMM.
Thanks once again. I don’t have a multimeter so will rely on the Flashlight, however I will ‘assume’ that it is reading 0.1v too high to be on the safe side.
I don’t understand the relationship with volts and amps in a battery yet, but plan on doing more research. I understand that a battery may have a capacity of 5Ah/5000mAh, and that if you use a device that uses for example 5A the battery will last 1 hour before running out of charge, but where Volts fits into this I don’t know.
Looking at the spec of the Samsung 40T I’ve bought the nominal voltage is 3.6V, which is below the 3.7V (half charge) you mentioned. As you can tell I’m a little confused
you are learning quickly… I respect your focus and specific question
3.6v is the “nominal” voltage of a LiIon that charges up to about 4.1 to 4.2 volts, hot off the charger
batteries often ship at half charge, and fall below, depending on storage time…
Thanks again. So in this example, when fully charged the 40T will have around 4000mAh and 4.2V of charge. If I use it until the flashlight goes out it will have (hypothetically) 0mAh and say 3.0V charge, however it it goes below 2.5V charge this could potentially become dangerous?
For ‘normal’ use I plan on using my flashlight at around 2000 lumens which I believe requires around 6A, which will drain a 4000mAh battery in around 40 mins. My dog walks are around 30-40 mins in a morning meaning that I’m going to take it well below half capacity, nearly until empty. Is this going to be an issue?
You won’t be able to run 6A with that light for 30 - 40 min. 6A is over 20 Watts at nominal voltage. I wish there were a spec for how many watts a light could dissipate but of course that varies widely depending on the temperature of the environment it is used in and how it is held. In one review the reviewer thought it could sustain 1000 lumen. Whatever the number really is I doubt it will be anywhere near 2000 lumen. If you set out to use it at that level you can feel good and not worry that you will deplete your light in a 40 min walk. Your eyes may not even notice it but unless your walk is really cold I am certain that the current draw will be cut considerably to control the temperature of the light.
Are you saying that it will get too hot at 2000 lumens/6A? The reason I thought this would be OK is that a fellow dog walker uses an Exposure Diablo which apparently is 1800 lumens and it only gets slightly warm. Obviously I have nothing to measure that it’s at 1800 lumens and so it could indeed be lower than that but it’s plenty bright enough :+1:
It only gets slightly warm because it has thermal management and that won’t let the light get that hot. 5A 6A for 1800 or 2000 lumen seems in the ballpark. Different LEDs have different efficiency.
Don’t know what light they use and I am not certain how the electronics inside the light will change the output vs the chart linked above. Nearly certain the output would have to be be lower than the chart but not sure how much. The specs for the light pretty much confirm that your friend is not walking around at 1800 lumen the whole time. They list a minimum run time of one hour with a 3500 mAh battery. That would be an average of 3.5 Amps. Looks like you coud get maybe 1400 lumen from that but given the fact that it starts at 1800 Lumen it would be drawing more for some time and therefore must settle down lower than 3.5A. Hopefully someone who understands how an actual flashlight is different from that chart can add to this.
Wow these things are complicated, whatever happened to just turning a light on and off again lol.
So if I’m understanding this correctly, whilst I might set my flashlight to 2000 lumens (hypothetically) it might only stay there for several mins and then drop down to stop it from overheating? If so is there something in the specs that tells me what the max setting is that it will run at without dropping down (at least for an hour or two)?
P.S. The Astrolux EA01s I’ve ordered is the XHP 50.2 version, I’ve no idea how efficient these are.
Thanks, interesting that if you want any kind of decent runtime it has to be below 1000 lumens. I’ve no idea whether that will be bright enough as my current light ‘claims’ to be 2500 lumens but the fact it runs off 3 x AAA alkaline batteries, and my friend’s Exposure Diablo that claims to be 1800 lumens is much brighter, clearly my current light is not 2500 lumens.
The link in the original post isn’t working and I was wondering what the best way is to ‘store’ batteries when the flashlight is not being used for an extended period of time? For non-protected Li-ion batteries is it best to remove from the light and store in a plastic case, or is it best to leave in the light so that it benefits from the low voltage protection supplied by the flashlight (Anduril). Likewise for a protected battery, I assume for a protected battery its own LVP would protect it regardless?
