Running on turbo puts a high current load on the cell which causes the cell voltage to drop as it gets pulled down; when you release the load you will get a bounce-back in the voltage as the cell recovers. This is a normal condition in a good cell. It happens fairly rapidly so you wouldnāt be able to remove the cell quick enough to see the droop on the DMM.
Thanks once again. I donāt have a multimeter so will rely on the Flashlight, however I will āassumeā that it is reading 0.1v too high to be on the safe side.
I donāt understand the relationship with volts and amps in a battery yet, but plan on doing more research. I understand that a battery may have a capacity of 5Ah/5000mAh, and that if you use a device that uses for example 5A the battery will last 1 hour before running out of charge, but where Volts fits into this I donāt know.
Looking at the spec of the Samsung 40T Iāve bought the nominal voltage is 3.6V, which is below the 3.7V (half charge) you mentioned. As you can tell Iām a little confused
you are learning quicklyā¦ I respect your focus and specific question
3.6v is the ānominalā voltage of a LiIon that charges up to about 4.1 to 4.2 volts, hot off the charger
batteries often ship at half charge, and fall below, depending on storage timeā¦
Thanks again. So in this example, when fully charged the 40T will have around 4000mAh and 4.2V of charge. If I use it until the flashlight goes out it will have (hypothetically) 0mAh and say 3.0V charge, however it it goes below 2.5V charge this could potentially become dangerous?
For ānormalā use I plan on using my flashlight at around 2000 lumens which I believe requires around 6A, which will drain a 4000mAh battery in around 40 mins. My dog walks are around 30-40 mins in a morning meaning that Iām going to take it well below half capacity, nearly until empty. Is this going to be an issue?
You wonāt be able to run 6A with that light for 30 - 40 min. 6A is over 20 Watts at nominal voltage. I wish there were a spec for how many watts a light could dissipate but of course that varies widely depending on the temperature of the environment it is used in and how it is held. In one review the reviewer thought it could sustain 1000 lumen. Whatever the number really is I doubt it will be anywhere near 2000 lumen. If you set out to use it at that level you can feel good and not worry that you will deplete your light in a 40 min walk. Your eyes may not even notice it but unless your walk is really cold I am certain that the current draw will be cut considerably to control the temperature of the light.
Are you saying that it will get too hot at 2000 lumens/6A? The reason I thought this would be OK is that a fellow dog walker uses an Exposure Diablo which apparently is 1800 lumens and it only gets slightly warm. Obviously I have nothing to measure that itās at 1800 lumens and so it could indeed be lower than that but itās plenty bright enough :+1:
It only gets slightly warm because it has thermal management and that wonāt let the light get that hot. 5A 6A for 1800 or 2000 lumen seems in the ballpark. Different LEDs have different efficiency.
Donāt know what light they use and I am not certain how the electronics inside the light will change the output vs the chart linked above. Nearly certain the output would have to be be lower than the chart but not sure how much. The specs for the light pretty much confirm that your friend is not walking around at 1800 lumen the whole time. They list a minimum run time of one hour with a 3500 mAh battery. That would be an average of 3.5 Amps. Looks like you coud get maybe 1400 lumen from that but given the fact that it starts at 1800 Lumen it would be drawing more for some time and therefore must settle down lower than 3.5A. Hopefully someone who understands how an actual flashlight is different from that chart can add to this.
Wow these things are complicated, whatever happened to just turning a light on and off again lol.
So if Iām understanding this correctly, whilst I might set my flashlight to 2000 lumens (hypothetically) it might only stay there for several mins and then drop down to stop it from overheating? If so is there something in the specs that tells me what the max setting is that it will run at without dropping down (at least for an hour or two)?
P.S. The Astrolux EA01s Iāve ordered is the XHP 50.2 version, Iāve no idea how efficient these are.
Thanks, interesting that if you want any kind of decent runtime it has to be below 1000 lumens. Iāve no idea whether that will be bright enough as my current light āclaimsā to be 2500 lumens but the fact it runs off 3 x AAA alkaline batteries, and my friendās Exposure Diablo that claims to be 1800 lumens is much brighter, clearly my current light is not 2500 lumens.
The link in the original post isnāt working and I was wondering what the best way is to āstoreā batteries when the flashlight is not being used for an extended period of time? For non-protected Li-ion batteries is it best to remove from the light and store in a plastic case, or is it best to leave in the light so that it benefits from the low voltage protection supplied by the flashlight (Anduril). Likewise for a protected battery, I assume for a protected battery its own LVP would protect it regardless?
You may know this already but beam characteristics can make a big difference in the perceived brightness of a flashlight. At the same distances a floody beam has the lumens spread over a wider area. A lower lumen narrower beam can have higher lux and can appear much brighter because the lumens are concentrated in a smaller area.
That can make it hard to judge the lumen output of a light.
Thanks, yeah I appreciate that. After trial and error Iām finding roughly 800-1000 lumens on a flood beam works for us. Iām basing this on my P20ix being 850 lumen in high.
