Hhmm. Did a 3X21A triple SFT-40 mod, cranked up amps I suppose with FET+1 driver, 16 AWG LED wires. Smoked one LED badly (BSOD) and a 2nd one mildly. Mistake I made was trying 30T's, took under 5 seconds, saw the output drop and quickly shut it down - was too late.
Swapped my "good" 3 SFT-40 MCPCB into the bad one, now using P42A's and 50G's -- all good. User will be using 50E's so even weaker, so should be fine.
I gave one emitter 9,5A’s from LD-4A and it developed black dots. It worked fine with 8A. Dot’s came off with electronic cleaner that shouldn’t hurt plastics, but beam turned purple. I mean really purple. I had black dots in my vision after beaming white wall for a minute.
The silicone layer over the phosphor is relatively thin (like compared to the XPL HI), so maybe that makes it more sensitive to flux splatter or debris?
It is good practice to wipe the LED with isopropyl after any nearby soldering. That splatter gets everywhere.
Yea, but I did a few mods with these and the modded lights never had a problem: TK-35, BOSS1, FF SP03 triple, BLF GT.
Think you guys are right about something getting on the surface of them. They are actually difficult to get things off of - the dye surface is in a depression, the edges are higher.
I actually don’t think there is any silicone layer on the phosphor at all. Its very soft and porous, especially compared to osrams, which almost look like they have a ceramic or sintered phosphor layer.
I can come back and report that my quad SFT40 light is still doing well. I cleaned it up with a Qtip and alcohol. The black spots became lighter in color but I wasn’t able to completely clean them off.
Since that time, I’ve ran the light a lot at even higher currents using 3*Samsung 30Qs instead of the 3*Tesla 18650s that I used before. There is no noticeable depreciation.
As stated above, I’m also inclined to believe the surface of the SFT40 is especially sticky for debris or flux splatter.
Just for the record, I’ve tested 2 SFT-40 as for now. Both had one dark dot. In one i have scraped off the dot creating a little crater on the surface. There’s a more violet area in the beam but visible only when zoomed out max.
The other one still has a dot, but so far works fine.
Both were purchased at KD.
Actually, there is some damage to my emitter which had the darkest black spot. I switched my light to another mode group today to get moonlight and found that the right-most emitter has some blue leaking from the right side (see pics). The blue is also noticeable in the beam if you look close enough. I’m a bit disappointed since I don’t think any emitter has had more than 7A, though it’s one of my only lights which I can’t test the current on. It’s not a huge deal but it will hold me off from buying another SFT40 light. I’m probably going to wait on ordering a Jin Heng JKK90 until the SFT70 comes out.
Its any news about this LED? I still waiting for my order. I must receive LEDs in few days. Maybe I will use 7pcs of this LED in my best headlamp. It will be crazy. But maybe not better as OSRAM CxLPM1.TG.
:D Trust me :D Its not joke. It is absolutely best headlamp/bikelight in the world. Amazing eletronic - 2x ARM CORTEX 48MHz 32bit, second DCDC for 3Volt logic,extreme output power, very lightweight, very extensive ribbing, lot of light mode - RGB, UV, lot of sensors - proxi, ambient, gyroscope, acceleromer, preparing Bluetooth... Wide input power supply (5)10 - 25Volt. Integrated fast charger/balancer/protections (not available now), GOPRO holder. 5 yaers developing..., before 2 yaers first light...
These are a hundred meters high rocks with 7xXPH50.2. But there is no right time to present these lights in the world... :???:
This is 7xCSLPM1, Not bad. (it's a short shutter - dark sky)
Do you want to know the next detail about this light?
So I infer that you built this? Whittling away some 7 years, which just so corresponds to your inscription on BLF yet stayed silent. No proper presentation of your project, your progress, hurdles and achievements. Then, of what reason for such light other than showing off. If I wanted to illuminate a cliff wall, I’d design a handheld lantern, not a headbanded light.
And throwing in all sorts of features, short of the kitchen sink.
Sounds more of a dream chaser than actual prowess.
Fabulation…
EDIT: Others may be curious about your contraption, but as for me, respect comes with a progression of challenges. Many have done so in the various threads here, and kudos for all the hard work and persistence.
