*BLF LT1 Lantern Project) (updated Nov,17,2020)
11892 posts / 0 new
sidpost
Last seen: 1 month 6 days ago
A question about my LT1 which arrived from Sofirn China about 6 weeks ago.
I was playing with Sunset mode and thought I had it set properly after a couple of test runs but, it was totally dead the next morning.  surprised
I plugged it into the port on my USB hub which I use with my cellphone (2A port) and let it run overnight.  When I left the office where it was charging, the switch glowed a steady blue.  Mid-morning the following day, I unplugged it and the switch began blinking blue.  I tried to switch it on and it glowed on a low setting and went out on its own and the switch color changed to steady orange.
I broke the contact with the batteries (twisted the base a few turns) and then tightened everything back up and never got the blue switch again, only orange.
Thinking the batteries weren't properly charged, I removed them put them into my Nitecore 4-bay charger which showed a good status on all batteries, and after a few hours put ~150mah  and less than 0.2V into them.  Reinstalling the batteries returned it to "normal" functionality.  smile
Is this user error where I don't understand what the LT1 is trying to tell me with the led colors in the power switch?  Or, do I possibly have a battery or lantern issue?  My other LT1 is about 4 months older (Anduril 2) and hasn't shown this behavior but, it also hasn't been totally depleted to absolutely flat batteries.  I also charge this LT1 on the same cable and charger port
The best thing I can tell from what I saw is that the "new" LT1 was trying to "CHARGE" the USB hub instead of taking a charge from it.  Perhaps, the power flickered out here in rural Texas while I slept, and the LT1 thought the "hub" was needing to BUDDY CHARGE?
DBSAR
DBSAR's picture
Last seen: 4 days 5 hours ago
Thinking the batteries weren’t properly charged, I removed them put them into my Nitecore 4-bay charger which showed a good status on all batteries, and after a few hours put ~150mah  and less than 0.2V into them.  Reinstalling the batteries returned it to “normal” functionality.  smile
Is this user error where I don’t understand what the LT1 is trying to tell me with the led colors in the power switch?  Or, do I possibly have a battery or lantern issue?  My other LT1 is about 4 months older (Anduril 2) and hasn’t shown this behavior but, it also hasn’t been totally depleted to absolutely flat batteries.  I also charge this LT1 on the same cable and charger port
The best thing I can tell from what I saw is that the “new” LT1 was trying to “CHARGE” the USB hub instead of taking a charge from it.  Perhaps, the power flickered out here in rural Texas while I slept, and the LT1 thought the “hub” was needing to BUDDY CHARGE?
Interesting.. I have not experienced that or tested that yet myself.
contigo
Last seen: 1 year 3 months ago
I am curious if there is a way to change color temp in this lantern. i got one not long ago but cant seem to find it in the manual.
In candle light mode its not yellow at all.
sidpost
Mine came setup with a warm candle and sunset mode.  Tint ramping didn't affect those modes at all.
Look for the Anduril 2 maps for options to adjust things.
Lixivium
Lixivium's picture
sidpost wrote:
Mine came setup with a warm candle and sunset mode.  Tint ramping didn’t affect those modes at all.
On my Anduril 1 LT1, I can tint ramp in candle mode.
contigo
found a youtube reviewer that explained it. thanks
supreme
Last seen: 1 week 2 days ago
Still worth purchasing? Any negative modifications by the manufacturer similar to what Lumintop did? I don’t want to purchase and find out Sofirn cheaped out on materials/made worse changes to the BLF model
sidpost
supreme wrote:
Still worth purchasing? Any negative modifications by the manufacturer similar to what Lumintop did? I don't want to purchase and find out Sofirn cheaped out on materials/made worse changes to the BLF model
I can't speak to what may be in the pipeline but, I have two LT1's from the "current generation" and love them.  They are my most used lights.
Considering its price point and what I see on the Sofirn website, I don't see any suggestion of these being "cheaped out" or otherwise being downgraded.  In fact, I see what looks like a new control board on their website to update the first generation LT1 lanterns to the current hardware and functionality but, I don't have enough knowledge to speak to the charging and similar features in the current generation, and this new replacement PCB.
TheIntruder
Last seen: 3 days 12 hours ago
What did they do, and to which model(s)?
Nearing time to order an LT1, but the CL2 also looks interesting.
sidpost
LT1!
It is a really awesome option with a lot of features.  The minor size difference in the CL2 had my attention for a little while but, the LT1 simply works so well for me and its feature set was better.  Plus, the 18650 batteries have worked really well for me during recent power outages.  I even overheard my friend's wife on the phone with my friend say "Sid has a really awesome light!" to him while I was over at the cabin chatting with her while the power was out.
CollectEverything
CollectEverything's picture
Last seen: 1 hour 14 min ago
Which version of the LT1 is considered the best? Is there a particular revision I should go for?
My Collection
iamlucky13
Last seen: 23 hours 52 min ago
I would say if you don’t specifically want to make sure you get any of the following features, don’t worry about which version you get. Any of them will still be the best lantern on the market:
– Powerbank functionality (I think this is universal now?) – Ability to change the maximum current by bridging or clearing solder jumpers – Pin arrangement for flashing new firmware.
If you do care, you’ll have to search upthread for information to guide which version to seek out, but I don’t think there is necessarily any certainty which version you will get, regardless of where you order.
Here’s two posts with some good summary info:
https://budgetlightforum.com/comment/1804061#comment-1804061
https://budgetlightforum.com/comment/1808175#comment-1808175
CollectEverything
iamlucky13 wrote:
I would say if you don’t specifically want to make sure you get any of the following features, don’t worry about which version you get. Any of them will still be the best lantern on the market: – Powerbank functionality (I think this is universal now?) – Ability to change the maximum current by bridging or clearing solder jumpers – Pin arrangement for flashing new firmware.
Cool, thanks for the info!
My Collection
Scallywag
Scallywag's picture
Last seen: 1 hour 19 min ago
TheIntruder wrote:
What did they do, and to which model(s)? Nearing time to order an LT1, but the CL2 also looks interesting.
Mostly the FW3-series lights.
  • To begin with, the FW3A was never produced to the manufacturing standards the FW3A team wanted. Hence the issues common to every version.
  • Lumintop made a few minor changes to the FW3A over time, then eventually some major unpopular changes: added a bunch of tacky-looking branding, and recently moved to a cheaper crappier driver
  • The FW1A used to be amazing, then they cheaped out on the reflector and it sucks now. Note that it appears they just used the FW1A Pro reflector (designed for XHP50.2 3V iirc) for all FW1As eventually. It's pretty bad with normal 3535 emitters
  • The 21700-series FW lights are reportedly, um, oddly designed and don't really fit 21700s very well. I don't own one, and I never will.
  • Early on they tried to bait-and-switch the optics (Carclo triple + glass lens) for something else that lacked the glass lens entirely. Backlash was bad enough that they switched back, at least for a while. Not sure if they ever went back to the cheap optics.
  • They continued to never get the tolerances right for the tail switch so they also made a version that relies on a proprietary battery instead, lol
  • With Loneocean's Lume1 project, they at some point just made it without his final revisions. Actually, I think that's kind of how the FW3A project went: the team still wasn't happy with the latest version they got, and then Lumintop started production.
That's all I can think of right now.
sidpost
I order mine from the Sofirn website because they are ~$10 cheaper, for me at least and, I always get the most recent revision.
I should also note I get the Orange LT1 which is hard to source from anywhere but, Sofirn.  I live in the USA and Sofirn ships out of China as fast as some of my shipments from Amazon.  Seriously, I average under 2 weeks from order to having it in my hands after shipping all the way from China to Texas.
I would encourage you to look on Aliexpress at the "web-store" and at the Sofirn website.
supreme
Who wants to start a group buy?
xevious
xevious's picture
Last seen: 6 hours 46 min ago
If you don’t need the powerbank feature, I think it’s best to go with the original LT1. For a while, Sofirn had them on sale to move old inventory. This Nov 11th, there could be another sale.
Firstly, the Anduril version in the LT1 v1 is excellent. Anduril v2 introduced minor improvements. Second, Sofirn started messing with the mcpcb and the LED indicators. I simply do not like the button glowing green when on. That’s meant for charge completion indication. The original glows orange, which is a proper color. Frankly, if it was green I’d be wincing every time I look at the damned thing. OCD? Maybe… but I’m grateful to give up the powerbank feature for orange.
sidpost
With reshipping and other overhead, not much of a savings there for the work involved IMHO.  If you shop carefully, you can come close to that price on singles.  Seems like my last one was a little over $60USD at my door.
sidpost
If you don't need the powerbank feature, I think it's best to go with the original LT1. For a while, Sofirn had them on sale to move old inventory. This Nov 11th, there could be another sale. Firstly, the Anduril version in the LT1 v1 is excellent. Anduril v2 introduced minor improvements. Second, Sofirn started messing with the mcpcb and the LED indicators. I simply do not like the button glowing green when on. That's meant for charge completion indication. The original glows orange, which is a proper color. Frankly, if it was green I'd be wincing every time I look at the damned thing. OCD? Maybe... but I'm grateful to give up the powerbank feature for orange.
Personally, I really like the bright Green power button on my LT1's.  On my SP36 I dimmed it and quickly restored it to full power.  My Astrolux FT03 is also Green which suits me just fine.
supreme
True. Just scored one for under $50 with batteries.
sidpost
That is a really good price!
Scallywag
Scallywag's picture
I grabbed a new powerbank LT1 driver with the intent of upgrading my first-run LT1. Had anyone else done this?
pol77
Last seen: 3 hours 56 min ago
No, but I also have a new driver and an original LT1. At first glance I could not see a marking on the ground wires regarding which connects to the warm and which to the cool LEDs. Or does not not matter, as i ramps both ways anyway?
whitecitadel
Last seen: 2 days 9 hours ago
I prefer my original as the low is lower and I use the lowest setting a lot I find when camping or using it as a night light for kids.
pol77
Thank you for this information! That decides it for me, lower low is much more important than power bank functionality.
whitecitadel
No problem, the newer driver board has no pads to configure the drivers in use, your fixed with whatever they used. Side by side I find the original (on default 5 drivers I think it is) to be lower.
The usb power bank model does seem to go brighter, and hotter!
supreme
What’s the difference between the 3 versions Sofirn has on their official store?
1
2
3
I believe #3 is the newest with the power bank function. The difference between #1 and #2 is #2 has Anduril 2?
whitecitadel
I lost count, but there are at least 5 versions of the original lexel pcp, these all have the pads to add the extra drivers if you want to add more output. The latest one, that is marketed as a power bank, is the sofirn driver the at has no pads, but you can use as a power bank.
The ones in the middle had small revisions to allow usb-c to usb-c charging and some other small increments I believe.
My two are the original first group buy, and the power bank one which I ordered without knowing it was a new driver as they had just switched over.
defloyd77
How did you manage that price?
supreme
11.11 sale, new user, and checked out with PayPal. $50-$60. I forgot which one of the 3 I ordered.
