Test/review of Vapcell INR21700 3000mAh T30 (Purple)
Vapcell INR21700 3000mAh T30 (Purple) 2021
Official specifications:
  • Model: T30
  • Size: 21.6*70.9mm
  • Typical Capacity: 3000mAh (0.2C discharge)
  • Min capacity: 2900mAh (0.2C discharge)
  • Nominal voltage: 3.60V
  • Max Continuous Discharge Current: 30A
  • Max Discharge Current: 50A with 80°C cut
  • End-of-charge voltage: 4.20V
  • End-of-discharge Voltage: 2.5V
  • Weight: 70g ( Appr)
  • Internal resistance: 8mOhm ( Appr) AC 1kHz
  • Standard Charge: 2000mA,CCCV 100mA cut-off
  • Quick Charge Current: 15000mA below 45°C
This is a high current 21700 battery.
The two cells matches very nicely and capacity is nearly constant at different loads.
Sadly my holder melted at the 30A test, probably because my temperature sensor was out of battery preventing my script from stopping the test if the battery got hot.
Conclusion
It looks like a good high current battery, it maintain voltage well at 30A, but may need a temperature cut-off.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Thanks a lot HKJ, “Internal resistance: 8mOhm ( Appr) AC 1kHz” Obviously it is not a Samsung 30T rewrap.
Based on spec and images, it might be the Chinese Qi Xin 21700.
Thanks HKJ!
Hey, what’s that smell….do you smell something burning? :slight_smile:
