Vapcell INR21700 3000mAh T30 (Purple) 2021
Official specifications:
Model: T30
Typical Capacity: 3000mAh (0.2C discharge)
Min capacity: 2900mAh (0.2C discharge)
Nominal voltage: 3.60V
Max Continuous Discharge Current: 30A
Max Discharge Current: 50A with 80°C cut
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.5V
Weight: 70g ( Appr)
Internal resistance: 8mOhm ( Appr) AC 1kHz
Standard Charge: 2000mA,CCCV 100mA cut-off
Quick Charge Current: 15000mA below 45°C
This is a high current 21700 battery.
The two cells matches very nicely and capacity is nearly constant at different loads.
Sadly my holder melted at the 30A test, probably because my temperature sensor was out of battery preventing my script from stopping the test if the battery got hot.
Conclusion
It looks like a good high current battery, it maintain voltage well at 30A, but may need a temperature cut-off.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
