Snagged one. Code worked. Thanks!
slmjim
slmjim
Semlos 6000 Lumen Super Bright Flashlight - 12 LED Tactical Flashlight
$18.91 with Amazon Prime
Portable Black Light Flashlight 365nm UV Light
$13.99 Amazon prime deal
Baseball bat type flashlight $16.14 Amazon Prime deal with an extra 35% off promotion
Rovyvon H3 Black Pen Flashlight 400 lumens Dual Power Source Nichia LED USB C Rechargeable Penlight Flashlights, Rechargeable Built-in Battery, Compatible 3A and 10400 Replaceable Battery
$15.95 with prime and an extra 25% off coupon
Those Sony are pretty expensive. Open box ones are tempting.
Could anyone post the coupon code for leather sheath? Struggling to login to vipon on my phone and really want 2 of those.
Sent you a pm with a code
Willcrew DX60 6000 Lumen Dive Lights Professional Scuba Diving Underwater Flashlight, 150M IPX-8 Waterproof Diving Torch Submersible Flashlight with 2 Batteries and Charger
$83.99 Prime deal and a $50.00 off coupon
* In the description and photos it shows a model number of “DF60” which is a Sofirn dive light. It looks the same , i wonder if it is indeed a Sofirn flashlight
Couldn’t resist that! Would have bought 2 but it said 11 left so wanted to leave another for BLFers
Lowes has the Model #GLM165-27C version for $99, on sale till Dec 1, usually $149.
Red laser but with the bluetooth app for data transfer.
Lowes Bosch Laser
All the Best,
Jeff
And thanks for the info on the flashlight!
I didn’t order one - trying to resist - down to 7 left !
300W portable power station for $29.99
The reviews are mixed but it can be returned until end of January if you get a dud.
UPDATE: It looks like the extra $100 coupon is now gone from the page.
Now down to 3 left, as of 6pm EST. I wonder what battery brand is “Volador”… never heard of them before. Would’ve snapped up one of these if the cells were Sofirn.
Bwana: dthrckt:Couldn’t resist that! Would have bought 2 but it said 11 left so wanted to leave another for BLFers
Have a couple Volador flashlights and they were the same as Thorfire which became Sofirn so do the math
habeba86: jeff51: habeba86: pennzy: habeba86:Rechargeable High Lumens LED Flashlight, Powerful 3000 Lumen Flashlights, Brightest Tactical Torch, 5 Lighting Modes, IPX7 Waterproof, Camping, Outdoor, Emergency, EDC Flashlight Amazon.com Not bad for almost $20 on sale
Doesn’t look half bad really. The specs say zoomable but I don’t think it is.
Its not zoomable,I have it.
How do you like it? What’s the UI like? Thanks
For what it is im more than happy with it. Battery is definitely not to rated mah, I think it was about 800 off. UI is high,med,low single click. If you hold the button it goes to turbo. It does drop down on turbo. Ill post some comparison shots to my edc18.
Received mine today. The UI is different than you posted - single click L/M/H/Off. Long press from anywhere, on or off, goes to Turbo. Double click from anywhere, on or off, goes to strobe. My only quibble is that if you single click you have to go through L/M/H to turn it off. No memory, either. Can’t speak to actual battery capacity or lumen output, but it did charge the battery to 4.19v and hold it there. Button changed from red to blue, not green, when it was fully charged - no biggy. For the $21 I paid, I’m very satisfied.
This light appears to be an Amutorch X9 clone, but in all aluminum (X9 has titanium and/or SS), different optics, different LED's, probably different driver. The size and design is a dead-on match.
X9 here: https://www.nealsgadgets.com/products/amutorch-x9
JeffN: habeba86: jeff51: habeba86: pennzy: habeba86:Rechargeable High Lumens LED Flashlight, Powerful 3000 Lumen Flashlights, Brightest Tactical Torch, 5 Lighting Modes, IPX7 Waterproof, Camping, Outdoor, Emergency, EDC Flashlight Amazon.com Not bad for almost $20 on sale
This light appears to be an Amutorch X9 clone, but in all aluminum (X9 has titanium and/or SS), different optics, different LED’s, probably different driver. The size and design is a dead-on match.
I have this generic version, I like it
Tom E: JeffN: habeba86: jeff51: habeba86: pennzy: habeba86:Rechargeable High Lumens LED Flashlight, Powerful 3000 Lumen Flashlights, Brightest Tactical Torch, 5 Lighting Modes, IPX7 Waterproof, Camping, Outdoor, Emergency, EDC Flashlight Amazon.com Not bad for almost $20 on sale
At least the “new” UI sounds lots better than the “old” one.
Willcrew DX11 1050 Lumen Dive Light Underwater LED Flashlight, 150M IP68 Waterproof Scuba Diving Torch Handheld Flashlight, 4 Mode, with Rechargeable Battery and Charger
$46.99 with prime and a $26.00 coupon applied at checkout
OK, good to know.
BTW, the low stock count reset. Now just “In Stock.” But the coupon changed from $50 off to $40 off. :weary:
I received mine today. Build quality seems decent, but the AC outlets don’t grab the plug very firmly. I didn’t open it up, but I’m guessing they are using some cheap PC mounted connectors vs a standalone outlet. It had a charge of 58% from the factory. The included charger charges at 60W and it took around 2-3 hours to get it to 100. The manual says it takes 5.5 to 6.5 hours to fully charge (from 0). I tried the AC output and it works fine. I don’t have a PD device, so can’t say if that is implemented properly. If it doesn’t die an early death (like some of the reviews said), then it is a solid deal at $30. I hope some other folks on here were able to grab one before the coupon disappeared.
