For Sale V10r w 219b 3000k 9080, $125,
Paypal G&S, free shipping in continental USA.
The light is brand new, old stock, I only opened it to do the LED swap, and to repack control ring grease with Nyogel 767a, for a very firm damping rate, that will not change inadvertently. Requires deliberate pressure to rotate the ring, and then it stays where you put it. The tailswitch is Forward clicky, which allows for Momentary On, at the Preset Rotary Dial position… No strobe.
CRI Ra tested at 96, Tint DUV tested at –0.0051 (Beautifully Rosy).
The stock reflector produces a very tight hotspot (because it is originally for XPG LED). Beam is excellent except when 2” away from a wall, a center cross is visible. This is normal and unavoidable, and exists also with the stock LED, on right:
outside of 3” the artifact is gone:
I consider the modded beam excellent (Im very picky)
Satisfaction guarantee: If for any reason buyer is not satisfied, I offer full refund upon return, buyer pays return shipping.
Includes free, installed used Titanium Bezel from V10r Ti. Original bezel also provided with the sale, and can be installed at Buyer request.
Output ranges from 0.16 minimum to 200 initial lumens maximum on 16340. Can also use, CR123, and if you buy the AA extender (available for $15), then also works on Eneloop (expect max output on AA and CR123 to be lower than LiIon).
This light is essentially identical in function to a V11r. The differences are the body design, and the more focused reflector. (V11r has an XML2 reflector).
Sale includes original box and pocket clip:
