Amazon Deal Alerts & Discussion Thread
300W portable power station for $29.99
The reviews are mixed but it can be returned until end of January if you get a dud.
Amazon Link
UPDATE: It looks like the extra $100 coupon is now gone from the page.
Now down to 3 left, as of 6pm EST. I wonder what battery brand is “Volador”… never heard of them before. Would’ve snapped up one of these if the cells were Sofirn.
Have a couple Volador flashlights and they were the same as Thorfire which became Sofirn so do the math :slight_smile:
This light appears to be an Amutorch X9 clone, but in all aluminum (X9 has titanium and/or SS), different optics, different LED's, probably different driver. The size and design is a dead-on match.
X9 here: https://www.nealsgadgets.com/products/amutorch-x9
I have this generic version, I like it
At least the “new” UI sounds lots better than the “old” one.
Willcrew DX11 1050 Lumen Dive Light Underwater LED Flashlight, 150M IP68 Waterproof Scuba Diving Torch Handheld Flashlight, 4 Mode, with Rechargeable Battery and Charger
$46.99 with prime and a $26.00 coupon applied at checkout
https://www.amazon.com/Willcrew-Underwater-Flashlight-Waterproof-Rechargeable/dp/B09GNG8LR6/ref=sr_1_118?crid=2HWCC0PJ3U7WH&dchild=1&keywords=dive+flashlight&qid=1635793210&sprefix=dive+flas%2Caps%2C165&sr=8-118
OK, good to know.
BTW, the low stock count reset. Now just “In Stock.” But the coupon changed from $50 off to $40 off. :weary:
I received mine today. Build quality seems decent, but the AC outlets don’t grab the plug very firmly. I didn’t open it up, but I’m guessing they are using some cheap PC mounted connectors vs a standalone outlet. It had a charge of 58% from the factory. The included charger charges at 60W and it took around 2-3 hours to get it to 100. The manual says it takes 5.5 to 6.5 hours to fully charge (from 0). I tried the AC output and it works fine. I don’t have a PD device, so can’t say if that is implemented properly. If it doesn’t die an early death (like some of the reviews said), then it is a solid deal at $30. I hope some other folks on here were able to grab one before the coupon disappeared.
I ordered one and should be here on Friday. If there is a problem with it, I’m not going to return it, but if necessary, I’ll scavenge the batteries out of it or something.
Interesting to note, it’s actually sold under several other names. One being, ALLWEI Portable Power Station 300W, and Newpowa Portable Power Station 300W.
The AllWei may be an older model that featured a solid “U” shaped handle that didn’t fold down. I’m sure it made it more difficult to store. The NewPowa version had the fold-down
handle, same as the PowerExtra. Another thing to note is that reviews on all three versions were mixed. I may open mine up before trying to turn it on just to check out
the boards and wiring just in case.
Bluetooth headphones $20
https://www.myvipon.com/product/8991460-Audonia-Active-Noise-Cancelling-Over-Ear-amazon-coupons
https://www.amazon.com/dp/B09FF39ZM6
WOOT says $16 will get you 4 of these with 12 batteries:
ORHFS 300W Portable Power Station (For Those That Missed The First One)
Although the same unit as the other deal, it’s $209.99 and $100.00 coupon off
for a total of $109.99. Not nearly as good a deal as the other deal from the other
seller.
Moobibear Smart LED Flood Lights, 2 Pack 40W Color Changing Floodlight
$32.00
First impressions: The build quality is not bad. The body is painted/powered coated aluminum. There’s no onboard controls, not even on/off - it’s all controlled by the a coin cell powered remote or ‘Magic Home’ app via Wifi or BLE. The remote is lacking. The app is well designed. it’s responsive and controls individually or all at once. I only tried bluetooth /local mode. it works without an account or wifi access. The CCT Tint and RGB colors are adjustable with a color wheel. Brightness dims to 1 lumen or less. CCT White is significantly brighter than the RGB mode. I doubt it’s 40w equivalent but it’s bright enough. Barely noticeable PMW in lower levels in camera. It could benefit with a diffusor. Overall it’s a pretty good flood light.
I snagged it, just came in. It’s brand new not sure why it was a warehouse deal. I expected the worst to get it loose in a bag or some random cheap light inside the box … but everything was like new didn’t look like it had ever been opened.
Super happy with my first zebralight . Thank you for posting!
With all the reports of smoke and fire it was only barely a good deal at $30. this one looks better to me at the $99 price point
https://amzn.to/3bUmP3L
code: XGZNKJRI
I received mine today. Has volador etched on it. Nice light!!
Great to hear! Mine arrives Friday, but I did receive this one today from the same seller, also with the Volador name printed on it:
$11.24 using code 503NBGAZ
https://www.amazon.com/dp/B08ZSC7JRX?tag=1sale06-20&linkCode=ogi&th=1&psc=1&customid&coupon_code=503NBGAZ
Another cheap meter—- I got one — because that’s what I do —- buy things I don’t need
https://www.myvipon.com/product/8975008-Digital-Multimeter-Tester-Voltage-Meter-USB-amazon-coupons&f=deal&search_tid=618557f95094bb4d2c216cb5
