Nice, photos seems to tell me this is what i need to use it as flood light!
Benckie,
1)Do u think this light can be switched on at high all the way till battery dead?
*things like >>is the heat desipating good? read that led scare heat, afraid it spoil on 1st time if i buy & gunned it on high long hours - will be using it like home light, the only time it will be shut down is when battery are flat & need changing - bout 8 hours run at a go>> maybe 3 hours on high, 5 hours low)
2)The medium mode is it like 50% brightness like other lights? (Think is safer for xml when using it as home light? also maybe 3 hours on high, 5 hours low)
3) Do u think this POPPAS W-878 is the best bang floody light for every buck/cents? Is there other lights capable of same/better flood with floodyness/intensity cheaper that you know of? (Cos have to get 4-6 piece )
Sorry for my english sentence structure, seems weired.
Reason for using 8 hours run on this is because i cannot bear to part with money to buy real floodlight or generator for electricity.
Thanks.
EDITED: Not running it every day 8 hour, is about twice or thrice every week - 8 hours run that is, rest of the time will be OFF.
