I'm interested, May I have a coupon please?
I`m interested too !
Replied.
Wanted to try this beast. Any code?
Share
Can I get the code? Seem really a hot buy
Just ordered a green, thanks for the code
Thank Freeme!
Ive been using mine every night for about the past 2 weeks and find it very practical under a wide range of conditions. Running QB26800 cells, its very impressive for a single emitter light of its size, maintains turbo without stepping down for several minutes (till it become nearly too hot to hold) and throws a usable even blanket of light a reasonably long distance. If anyone is still on the fence, get one and never look back.
The next logical step for Mateminco would be a SFN55.2 version of their MT01 to round out the collection. Maybe you could ask them to consider it and put together another group buy for us.
I’ll second that. That MT01 size, 26800 cell and the SFN55.2 LED would be a really flexible large pocket light. That driver would let me go from sub lumen up to 6200. Should have better throw than the quads in this size.
Thanks you! Bought one all black for me
Interested
Interested. Can I get a code. THX
Coupon Code Request, for MT70 MINI. TY
Does the driver have flashing pads? I’ll pull the trigger on Taobao if I can flash Anduril.
Yes it does, you need to unscrew the retaining ring to reveal it.
Hello! May I have a code please?
I am considering buying a blue w SS bezel from Neal. He also sells 26800 tubes designed for the MT04. I wonder if they will LEGO fit.... Can anyone tell me how/where they sourced the 26800 tubes using with the MT70mini?
I am really excited about using the QB26800 6900mAH cells with this setup. Can anyone recommend a source for these cells within or close proximate to the US? How about the 26890 available cells?
Sincere thanks FREEME for your efforts!
Here, great price: QB26800 6800mAh 3.7v Li-ion Flat Top Battery (alofthobbies.com)
Many have bought them from here, recommended.
This is the tube you need. https://www.aliexpress.com/item/1005003048085331.html The MT04 will not fit.
I'm interested too but shipping is crazy $$$ - bump the qty to 2 and US shipping goes from $8.50 to $28.50.
Guess if you order qty 1, it's the same cost as BG has it listed: https://www.banggood.com/26800-Battery-Tube-For-Astrolux-FT03-FT03S-LED-Flashlight,DIY-Extended-Body-Tube-For-Large-Capacity-Longer-Runtime-26800-Battery-p-1865528.html?rmmds=myorder&cur_warehouse=CN&ID=6287837
Think freeme had a $5 off coupon back in June/July timeframe. The FT03 tubes should fit: FT03 = MT35 Mini = MT70 Mini -- I think??
freeme's deal on the FT03 w/26800 tube and batt: https://1thedeals.com/product/astrolux-ft03-xhp50-2-sst40-4300lm-narsilm-v1-3-usb-c-26800-flashlight-bundle/
we just need the deal in black/blue/green and with the SFN55.2 LED :FACEPALM:
CHEERS TOM! Thanks for the recommendation! That's a third of the price of the 26650 5500mAH 30A Shockli cells I would have used AND here in CA!
Now, can anyone give me any insight as to where to source a 26800 battery tube for the MT70MINI? Can I use the extension tube designed for the MT04 that Nealsgadgets.com carries?
THANKS!
