NEW 5 digit dual current range 60V 12A power supply RD6012P is released now
Hello, our new product RD6012P 5 digit dual current range power supply is coming. Hope you like it and you can check the product information and make order in the link below:
As what we do all the time, we will set the lowest price when new product is released, so here is the price:
RD6012P:$79.99USD (normal price:$103USD)
RD6012P-W:$83.99USD (normal price:$108USD)
We also prepare the S800 case and input 800W PSU for you to assemble them together to make a complete power supply.
Discount Time: 2021.11.5-2021.11.10 PST.
Because of dual current range (6A/12A), this price is even lower than RD6006P, so you can get the RD6012P with lower price when its performance is better than RD6006P, because when switch to 0-6A range, RD6012P can be used same as RD6006P.
RD6012P supports dual current range,it is 5-digit display,you need big current, you choose 12A range and you can get 0.001A resolution, if you need low current with high accuracy, you can switch to 6A range, the resolution is 0.0001A, useful function: )
They opened in another browser! This is finally getting to the size that they are becoming more useful. I have been holding out for a little more power, my old HP bench unit is only 3A, but it is an honest 3A. It would be great to have say 20A in the 3.5 to 4V range, but that is not an option with budget minded supplies at this point. This one may finally get me over the hump. My HP is so old that I have replaced the caps 2 times in its lifetime and have had to rebuild part of the regulator circuit once. Next time it dies, might just be the end of it.
20A should be the old DPS5020, yes, it is 1.44 inch screen and no keypad, 18A should be the RD6018 power supply, yes, it is 2.4 inch screen and keypad control, more user friendly, and it adds more function, so the price is higher than DPS5020
Hello, RD6012P supports parameter color changing, if you like other color for the display, you can set it in the setting page, so that you can get a display which is more convenient for you to read
RD6012P supports 3 display style(classic style/detail data style/curve style), you can switch the display style by pressing thearrow button, choose the one you need, it is very convenient and user friendly
today is the last day for RD6012P promotion, and it will end at 11-10 PST, after that, though it is 11.11 promotion, the price will not be lower because our tradition is to release product at lowest price when it is released https://aliexpress.com/item/1005003472332331.html
there is already feedback for RD6012P(we sell them in China first for Public Test), this customer use 15 days to make a diy power supply,he adds 3.3V 5V 12V Four-way Adjustable module, Soldering Station, supports 100W PD fastcharge....very good https://aliexpress.com/item/1005003472332331.html
hello, for our DC to DC power supply, if you want to use AC input. you need to use an AC to DC PSU to power on our device, and you need to be careful when choose the PSU, it is recommended to use switching power supply( no matter ours or other good quality brand),for converter or transformer, be careful because if your input AC voltage changes to a high value in short time, it will also output high voltage to damage our device, and you had better not to use electric bike charger or second hand PSU or modified PSU because their output are extramely unstable
I have the DPS6020 (20A) and it would be nice to have more current.
I would buy a 30 or 40A power supply, even if it has lower voltage.
I only use stuff below 30V anyways.
