I’ve tried everything including straight razor last year just because and to learn to sharpen it. But all I use now are portable shavers powered by Eneloops.
The naked blade seems like an accident waiting to happen though. What if someone comes along and bumps your elbow? What if you just woke up and are a little groggy?
I quit shaving several years ago. It’s extra work for which there is no compensation. Now I just buzz my beard off with the clippers whenever I cut my hair. My wife likes a little facial hair. I’m not sure if she likes other forms of laziness or just that one.
They’re not dangerous. Geometry is made for shaving, not killing. Every once or twice a year I have a small cut, but no scars thus far. One rule tho - if it falls down, let it fall.
I’m not trying to say it’s an aSsAulT wEaPON. I just worry about accidents with a sharp blade. The idea is appealing to me otherwise because you aren’t throwing something away all the time.
Been using tracII style, no pivot, no fancy since the 70’s, guss I’m stuck in a time warp. The newest blades offer nothing to me and I typically get 30 shaves/blade. At this price I get 8 years of shaves for $15. The more money I save on shaving = more $ for that flashlight I really might not need, but I gotta have https://www.ebay.com/itm/294348142090?hash=item448884360a:g:lbcAAOSwPolhIJQx
That’s a great deal but I have never found a generic Trac II that was any good. My beard is coarse and even though I only shave my neck, I go through Trac IIs pretty fast. Do you think these are close to Trac IIs in quality?
Edit - BTW, they are only $11.98 at Amazon.
there are lots of ways to save money shaving….here are some that worked for me:
1. as how crazy is this posted: rinsing and drying any blade will save it from corrosion, which is the #1 thing that ruins a sharp blade.
2. proper (and cheap) beard prep will help those older blades keep on keepin’ on.
3. cheap hair conditioner works as well as the expensive creams. for me, anyway.
Get yourself an old Gillette adjustable (Slim or Fatboy) and start on a low number. Unless you have a fairly wrinkled face (I mean that in the kindest way possible) there aren’t any problems that cannot be solved to get a good and pain free DE shave. Also as a bonus, they are the best blades to slice LEDs.
That’s the brand, but not the ook I was referring to. This is listed as “beard cream”. Btfoom what it’s supposed to do, but it’s got good stuff in it, and doesn’t smell like a funeral parlor like some other products do.
I’ll use Gold Bond on my hands, more specifically knuckles, because otherwise they get too dry and literally split, and seems like a bunch of little paper-cuts. And a coupla big ones.
My hygrometer is already at 24% RH; at/below 20% it just stops reading and goes “LL”. Wheee. Hell, just petting my cat, I was feeling little shocks and hearing crackles, so no wonder he ran off after a while. And nope, I don’t have the heat cranked up, as it’s only a chilly 66° in this room.
So yeah, winters are pretty much a dry The Hell over here. I know how Ashy Larry feels…
Ah yes. I wish the straight razor would have been established in private households for that reason. It never happened at large scale and shaving was done mostly in the barber shop. The safety razor (I like those too) has, and later the cartridge system razors, which added plastic waste :-(. Don’t fear those small cuts. The way you hold it guarantees it cannot cause deep wounds, even when your kid bumps into you while shaving. You’re shaving with almost no pressure, at an angle that can be considered safe.
Have you ever thought about using an electric razor for the first pass or two, then follow with a wet shave to get that closeness you desire? I’d found that my greatest troubles with wet shaving have been long or thick whiskers. On a day when I want to do a wet shave, I found making an initial pass with my electric razor eases the path for the really fine cutting you get with wet shaving.
I use water and a safety razor to keep my beard trimmed up. It was irritating at first, but my skin got used to it quickly and I don’t notice anymore. I paid 10 bucks for a sampler pack of blades a few years back, and in another 5 or 6 years I may need to buy more blades. All in all, it probably only costs me a few cents a year to shave.
