hi guys,
in the parallel thread ( https://budgetlightforum.com/t/-/68439 ) i am showing the progress from the beginning to now - but since its a long way, i want to show you my latest project seperate in more detail.
lets start. two years ago i build a small amount of EDC Flashlights with 16340 Battery. I use them very often, but they are limited in brightness and endurance. So i decided to start from a white piece of paper and develope a bright, very strong flashlight with handsome proportions with bigger batteries.
that was my first draft:
two variants, one for 18350, one for 18500 batteries. good enough to give it a try. But before starting with the production, there is some addional planning required. one of the issues producing this kind of parts is the clamping of the parts. for that i need some tools. furthermore i need some master threads, so that every single part i will produce on my conventional machines will fit to every other part.
thats the result: a master thread for every part and at the same time a clamping tool for outside machining:
some hours later:
after that i could start machining the flashlight parts itself:
here as an example the battery tube on the lathe:
some moments later the same part is on the milling machine with the clamping tools, i showed some pictures above.
and here the heatsink, first meassuring, than milling:
and here it is, the first prototype:
after using it for some days, its my favourite flashlight. But i realised, that it is not perfect. Two things are disturbing me. The position for the clip is not feasible. If i would set threads in the battery tube in the planned position, the light would be water resistant anymore. and i have no possibility to add a lanyard. So i updated my first draft:
i moved the clip to the back and added some holes in the rear for fixing a lanyard:
a little challange was the production of the "tailring". its a really small part with some turning and milling operations on it.
but maybe you ask you, how the hell can i screw that ring into the tail of the light ? i had the same question But luckily i have a CNC Mill, so i could produce a small tool for that:
after having all parts finished machining, lets make some group photos:
these 3 lights are now finished with machining. In the next step i will put them into a thumbler, a rotationg barrel with some grinding stones in it to round up the sharp edges. After that, i will polish one light, the other one will get sandblasted. Then i will have them coated with a DLC (Diamond like Carbon)
i never did that before, so i am very excited, how that will look like.
thats from my side for today, i hope you like my work and i will update that thread soon.
see you
Michael
