New 5 digit RD6012P Power Supply is coming soon
They opened in another browser! This is finally getting to the size that they are becoming more useful. I have been holding out for a little more power, my old HP bench unit is only 3A, but it is an honest 3A. It would be great to have say 20A in the 3.5 to 4V range, but that is not an option with budget minded supplies at this point. This one may finally get me over the hump. My HP is so old that I have replaced the caps 2 times in its lifetime and have had to rebuild part of the regulator circuit once. Next time it dies, might just be the end of it.
They have a 20A PSU but it’s the older design with a small screen and subpar interface, I use it regurarly to test my drivers.
They also have a 18A one with a bigger screen and more buttons but it’s significantly more expensive
thank you so much, I will consider that
Why not to try to design dual power suplly with serial parallel capabilities like 30V 12A of channel?
in the RD series power supply, we do not add that when we design it, in the next series, we will consider to add that
20A should be the old DPS5020, yes, it is 1.44 inch screen and no keypad, 18A should be the RD6018 power supply, yes, it is 2.4 inch screen and keypad control, more user friendly, and it adds more function, so the price is higher than DPS5020
yes, blf cannot upload local picture, I can only use the facebook picture link
15 colors, custom your unique display
Hello, RD6012P supports parameter color changing, if you like other color for the display, you can set it in the setting page, so that you can get a display which is more convenient for you to read
3 display style can be chosed, swich as you like
RD6012P supports 3 display style(classic style/detail data style/curve style), you can switch the display style by pressing thearrow button, choose the one you need, it is very convenient and user friendly
today is the last day for RD6012P promotion, and it will end at 11-10 PST, after that, though it is 11.11 promotion, the price will not be lower because our tradition is to release product at lowest price when it is released
https://aliexpress.com/item/1005003472332331.html
there is already feedback for RD6012P(we sell them in China first for Public Test), this customer use 15 days to make a diy power supply,he adds 3.3V 5V 12V Four-way Adjustable module, Soldering Station, supports 100W PD fastcharge....very good https://aliexpress.com/item/1005003472332331.html
hello, for our DC to DC power supply, if you want to use AC input. you need to use an AC to DC PSU to power on our device, and you need to be careful when choose the PSU, it is recommended to use switching power supply( no matter ours or other good quality brand),for converter or transformer, be careful because if your input AC voltage changes to a high value in short time, it will also output high voltage to damage our device, and you had better not to use electric bike charger or second hand PSU or modified PSU because their output are extramely unstable
I have the DPS6020 (20A) and it would be nice to have more current.
I would buy a 30 or 40A power supply, even if it has lower voltage.
I only use stuff below 30V anyways.
thank you so much for your support , i can understand your request, I will consider , and tell our engineer
RD6012P feedback
he might be late, but he always comes with his special metal panel
https://www.aliexpress.com/item/1005003472332331.html
There will be Black Friday Sale at the end of November, the discount will not be same like 11.11 sale, but it will still be lower than normal price, so if you miss the 11.11 sale, you can make orders for RD6012P at Black Friday Sale
RD6012P feedback
good product and good performance(PS: if you use lower than 6A, you can choose the 0-6A range)
Black Friday Sale will start from 25th and end at 29th, the discount will not be same like 11.11 sale, but it will still be lower than normal price, so if you miss the 11.11 sale, you can make orders at Black Friday Sale, and it is a good chanse to order RD6012P with lower price
https://rdtech.aliexpress.com/store/923042/pages/promotion-20211129.html
the first thing he did when received RD6012P is taking apart it and remake a new one
for our RD series power supply, we pack them well, and the box is covered by plastic film, the device is well protected, and it is also a easy way to see if someone has opened it before you get the package.
