【convoy】H4 and B35AM options are updated
Hi Simon,
a user has reported a problem with the H1 219b TIR on reddit with the TIR optic not touching the pcb.
https://www.reddit.com/r/flashlight/comments/qmuj8v/convoy_h1_with_tir_tir_not_touching_led/
Do you have any info on that?
Beam as sold:
Beam after pressing TIR on pcb:
More info:
I will have another flashlight similar to M21E. The head is slightly smaller than M21E, but slightly larger than M21B. It uses the same driver as M21E.
Pioneman is my friend’s brand.
I am going to release this flashlight, but I hope to use a driver with a higher current.
If the increase in range is not obvious, the larger diameter head seems meaningless.
I am applying for samples from LUMINUS.
MCPCB is not a problem, I can ask the manufacturer to produce the corresponding MCPCB according to the size
Thank you so much for your feedback.
Next week I will produce some 16*1.5mm copper plates. It can be used to raise the LED position.
I can’t find a suitable TIR lens at present, and all the lenses will be much lower in height than the reflector.
Super !
MCPCB might be a problem for me : in addition to my convoys, i’m on modding wurkkos HD20 and sofirn SP40 that have non-standard MCPDB shapes
Thank you!
What luminus emitter are we talking about?
The problem it’s only with 219b or the XML2 TIR have the same problem?
Nice I see today Simon launches new headlamp H2 with USB-C charging port. Interesting replacement of H1 but here also missing feature is magnet in tailcap.
https://www.aliexpress.com/item/1005003514653823.html?spm=a2g0o.store_pc_home.productList_644232540.subject_0
This is what separates Simon from others. Swift acknowledgement and response to feedback. This is excellent.
Thank you Simon.
Have the group issues with the 13 group AA/14500 driver been fixed yet? The T3 and bare drivers I got have incorrect groups 12 and 13. I wanted to order a couple more drivers if they aren’t still messed up.
For this batch, I will correct the modes as follows,In the next batch of production, I will adjust it according to your opinions, and I can add more groups to meet your requirements.
I hope everyone can express their ideas enthusiastically.
Group 1 1, 10, 35, 100
Group 2 1% 10, 35, 100%, strobe, biking, batcheck, sos
Group 3 100, 35, 10, 1
Group 4 1, 20, 100%, strobe, biking, batcheck, sos
Group 5 1, 20, 100%
Group 6 100, 20, 1%
Group 7 1, 10, 50%, strobe, biking, batcheck, sos
Group 8 1, 10, 50%
Group 9 50, 10, 1%
Group 10 20, 100, strobe
Group 11 20, 100
Group 12 100, 20
Group 13 100%
So are the ones currently listed the fixed ones?
5-40(50)-100 would be greatly apreciated in all drivers.
I don’t see the appeal of that mode spacing. On the three 12 group lights I’ve tried, even 20% and 100% seem too close. There would be almost no difference between 50% and 100% from most emitters.
yes, the middle mode max 40%
To you maybe, zo me and others with a specific work demand yes.
As i mentioned previously in this thread, i’m running Nichia B35AM in S21B with 6V/3A 12group driver and a lack of 40-50% mode in the middle is causing me a headache cause i’m constantly switchi g from 20% to 100%. Higher medium output would do the trick. I need 800lumens and 400Lm is just not enough and 1800lm is too much.
5-40-100 would be also great
Are the drivers currently shipping already corrected?
