soda can light with sustainable high output?
The Imalent MS03 is pretty close to this on the low and medium modes.
But probably the main thing it’s used for is 10 seconds of turbo.
I would guess your next step in progression would be a soda can size thrower. Have you considered a Convoy 4X18A Cree XHP70.2 ? HERE
Or at Neals Gadgets HERE
I have the 90.2 version, but the run time is short, the 70.2 version is better. If you get the 4K version the CRI should be higher and the price is cheaper. :wink:
I have the Convoy 3×21A and its a marvelous light, Tremendous power and sustained output. Takes standard 21700 batteries, not that proprietary nonsense. At $65, its a no brainer.
I like that one too. :smiley:
Thrunite tn36 limited will sustain a very high outputs (near to its 8000lm high I believe), but has a correspondingly high thermal limit).
I did not include driver efficiency as parameter because even the FET drivers without 7135-bank are in most modes sufficiently efficient, the difference with nice current regulated buck-drivers is often not more than 10, but agreed that is a factor too. In the worst case design the FET in fully open mode drives the leds right at their max (I do not consider this a well-designed flashlight) and is then PWMed to 30 to reach max sustainable lumens.
My M6 with 3xXHP50.2 and 16xAMC7135 will sustain full regulation until the battery voltage drops below regulation :slight_smile:
Maybe Q8 Pro can do well?
Yep … Convoy 3X21A … great light for your needs.
+1 on the Thrunite TN36
This is very interesting to me in that efficiency by definition should be a critical factor to this. However, the least efficient LED light that I have can sustain about 1k lumen for hours on end and not even get very warm to the touch. Roughly 76 lumen per Watt. However, that is not a flashlight — it is an under counter light. No idea how many LEDs it has but certainly at least dozens. These LEDs are laid out over about 62 X 600 mm. Don’t think there is a way to do anything like this with a flashlight. Must be just too expensive to use more efficient LEDs in the under counter lights. Should be closer to 6 watt rather than 13 but apparently, getting the efficiency out of counter lights would be just too expensive to justify.
Thank you for all the replies, everyone! I realize this form factor will limit heatsinking.
Great list, Dave! I’d been poking around on 1lumen for the excellent runtime tests, and your list is very helpful. :+1:
I had already been ogling the Acebeam X50, which looks to be the top performer in terms of sustainable output in this class.
Simon’s 3X21A looks like an amazing bargain! This one had somehow flown under my radar.
Take a look at Lumintop GT3.
When I received my unit, I conducted a ~35min test run. Judging by eye, I set the brightness to a level which corresponded to ~70%(again judging by eye) of the brightness of my BLF SP36 LH351D 5000k when on TURBO. Head temperature stabilized and didn’t exceed 59,3°C(measured with pyrometer), body temperature stabilized at 54,5°C and didn’t exceed that. No step-down during this test.When I received the light, I calibrated the temperature sensor and set the thermal limit to 70°C.
I know it’s not very scientific, but for me it somewhat confirmed the impressive performance showed/stated in zeroair’s review.
Cheers
If only it had a tripod mount like the Q8!
If I need several thousand lumens to be sustained, my go-to lights are either my Trustfire TR-J20 or my favorite, the Trustfire TR-S700
Both are heavy lights as seen from some of the specs for the TR-S700 below, but a great deal of heat sinking is necessary to shed all the heat.
The lumens listed for the TR-S700 are actual too.
Model : TR-S700;
Dimensions : length 195 mm * 90 mm diameter ;
Weight: 1278 g;
The light source (LED ): 7xCree XM-L;
The maximum luminous flux of 3800 lumens
Out of curiosity, which LED are you guys recommending in the 3x21A, the SST40 version or the 90.2 version?
SFT40 is the one everyone is getting.
AFAIK, the SBT90.2 only comes in the 4x18 which is very similar except it takes 4 x 1865s.
I am looking at the Imalent MS08
Great response Dave!
I love my X80GTvn. Turned off by X50’s proprietary batteries and hoping the new Manker MK38 is better.
There is a 3x21A SBT90.2 https://www.aliexpress.com/item/1005003189683649.html
But if we are going for sustained output, the SFT40/SST40 would win.
I ordered a Convoy 3X21A with 5000K SST40 emitters. I like Simon’s products and the excellent price (including cells) was too good to pass up. :partying_face:
I’ve enjoyed everyone’s input and am still considering other lights, so let’s keep this thread going!
I’m still tempted by the X50, but the built-in battery is a turn-off.
