JSC Energiya INR18650 3000mAh LITS-3 (Blue)
Official specifications:
Nominal capacity: 3000mAh
Nominal voltage: 3.6V
Maximum discharge current: 2C (6A)
Charge voltage: 4.2V (Other specification say: Open voltage 4.1V).
End of discharge voltage: 2.5
Cycle life: 300 cycles to 60% (Other specification says: Service life 500 cycles).
This is a Russian manufactured 18650 cell with good capacity, but fairly low current capability.
The cells match fairly well and can deliver the rated current, in my test I went significantly above that and the cells died (One a 15A the other at 20A).
Conclusion
The cells works nicely, but are not top of the line cells.
Notes and links
The batteries was supplied by a reader for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
