Thanks, and good catch, lol. It’s actually 4000k, just edited my post. It’s from mtnelectronics.com, I bought several.
I also worked on a few more flashlights today. I swapped in a 219C 4000k into a AAA Coast G22 flashlight, and added a diffuser as the reflector had an ugly beam.
I had a SS SingFire 14500 flashlight laying around, and also put a 219C 4000k into that, along with a 45 degree TIR.
LED swap in a Skilhunt H300. Previous LED was cold white and low CRI. Used an XHP50.3 4000K 90 CRI from Digikey. DUV is a little positive (slightly green) but overall much nicer.
The stainless bezel had little divots, but I couldn’t get it unscrewed using normal tools so I designed and 3D printed a tool to remove it. Worked perfectly!
Gigantic parasitic drain. So much so that I suspect the light was defective. It would actually drain a full 18350 in less than 24 hours while off. This is pretty gamebreaking, because the only way to avoid it is to do a tailcap lockout, which I hate doing.
Charging port hatch cover is poorly designed. It sticks out, is flimsy, and doesn’t lock into place securely. Not a big issue since the cover is optional. The port itself is waterproof according to Eagletac so the cover is just there to keep lint out.
I noticed that current flowed between the positive and negative pads on the bottom of the driver when the head was not connected to power. I got around 400 ohms resistance, which seemed high.
I managed to remove the driver, but in doing so I ripped off the 3 tiny wires for the charging port. Oops! Even worse, they were so tiny that even after spending 15 minutes with a magnifying glass I could only find one of the bondpads that they were attached to. I ended up permanently disabling the charging port by clipping off its wires.
This light was a royal pain to reassemble. I have no idea how they managed to assemble the thing at the factory. The plastic jacket that sits inside the rubber switch presses so firmly against the switch on the driver board, I was barely able to get it in even after filing the corners down.
Without the charging port attached, resistance between the positive and negative pads on the bottom of the driver jumped to 685,000 ohms. Hopefully, this means less parasitic drain. My cheap mini DMM doesn’t measure current so I’ll stick a cell inside tonight and see what the charge looks like tomorrow.
Guess I’ll also epoxy over the charging port since it’s no longer functional.
I like it but I would like it better if it could have proper MCPCB fixation. I mean is it possible to have absolutely firm MCPCB with some kind of magnet or other type of fixation?
Yes 2 hands are better than one but only if mcpcb is fixated… If mcpcb is wandering around on touch(emitter centering, final tap press) it is still better to do Old Lumens method with small benchvise and big soldering iron tip beneath mcpcb (regulation over soldering Iron station is possible).
But I would like your system better only if there is possibility of MCPCB fixation. Because we don’t actually have 2 free arms if I got to hold MCPCB with one hand and then centering with other (for emitter centering and final tap or press)?
Today I swapped the quad XP-L HI LEDs in my D4 for 4x LH351D 4000k. Probably one of the easiest swaps I’ve done as the new copper MPCB from mtnelectronics was plug and play with the D4. I like the tint much better.
Now I need to find a new home for the quad XP-L HI board.
Forgot to post this earlier. I also swapped a 219C 4000k into an I5T EOS.
Not really a mod but maybe useful for someone. As you all know Petzl Swift RL is not really waterproof, it’s only IPX4
Since you can’t really do much about the plastic body as it has too many holes I was trying to waterproof the electronics with 422C Conformal Coating
Here are some photos of internal components:
The electronic board with two Osram Oslon ? leds and photo sensor on the left side
The other side with heatsink and controller ( STM32F )
Closer look at the LED emitter
The board after coating applied ( in UV )
Modded a Wowtac A6 last night into a triple. New emitters are SST-20 95 CRI.
I used the stock driver. I didn’t even remove the driver to drill a new hole for the driver wires.
I filed off around 1mm of the edge of the star on all sides so it would fit, then I filed 2 notches in the star for the driver wires, and used short bits of wire to extend the stock driver wires to the contacts on the star. I also snipped 1 leg off the Carclo 10507 optic as it was getting in the way of the inside knob of the USB port cover.
