C01S is a tiny Keychain light that is upgraded from BLF C01. With 2 modes and update to 100lm output. It is designed for finding keys, reading, EDC and emergency, etc. It can be operated from a single AAA battery (Alkaline/ Ni-MH). Rotate head to turn on / off.
Features:
Compact size more portability
Case Material is 6061 aircraft-grade aluminum,hard-anodized anti-abrasive finish, and better heat exchange
Stability, heat resistance, cold resistance, anti-fall, anti-pressure
Specification:
Head diameter: 14.5mmCRI (min): 95
Working Voltage: 0.9V-1.5V
Battery Options: One 1.5V AAA Alkaline battery or one 1.2V Ni-MH battery (Neither Included)
Flashlight body: Aerospace graded 6061 aluminum alloy, CNC manufactured to hard-anodized anti-abrasive finish to get the solidly built body, anti-crash geometry, and better heat exchange.
DIY Enabled: the tail cap stands upside down; the round hole is for a 5mm (diameter) magnet, and the other is a trit hole (magnet and trit not included)
Operation Instruction:
When OFF, screw down the battery case to turn on and modes from low-high; unscrew the battery case to turn off.
When On, unscrew the battery case to turn off and then rapidly screw down the battery case to change the mode; no memory function and default brightness is Low mode.
Head diameter: 22.7mm
Tube diameter: 21.2mm
Impact resistance: 1.5m
UV Intensity: 4700μW/cm2@38cm, 28600μW/cm2@15cm
UV flashlight has multiple usages as below:
Check the leaks in air conditioner and automobile circulatory system
Mark and blood inspection, examination of crime scene
Treasure and minerals searching, antique appraisal
Ink curing and glue curing
Identify counterfeit bills
Gas leaks inspection
Fluorescent reflection of special materials
Head diameter: 69mm
Tube diameter: 50mm
Waterproof level: Life waterproof
Low voltage warning: automatic power off
Illumination: Maximum 314.7KCD
Reverse polarity protection: None, the positive side of the battery should be facing the head
Mode operation instructions:
Click the button -> flashlight is turned on with last brightness -> press the button,brightness ramping up -> release and press the button again,brightness ramping down
Flashlight off, press the button -> moonlight mode 0.01A (0.2%) (This brightness will not be remembered)
Flashlight on or off, 2-click the button -> turbo 100%
Flashlight off, 3-click the button -> strobe
Flashlight off, 4-click the button -> tactical mode, only 100%, 4-click the button again to quit tactical mode.
Flashlight off, 5-click the button -> voltage detection (* means “flash”, * suspend* means 3.7V )
Flashlight off, 6-click the button -> ramping mode switch to 4modes 1–10–40–100
Flashlight off, 10-click the button -> Lock mode, The flashlight will flash once under any operation, which means the flashlight is locked. 10-click the button again to quit lock mode, please note that this is the only way to unlock.
Please note:
If you put the flashlight in a bag, be sure to loosen the connection between the battery tube and the head. Otherwise, the flashlight may be turned on by mistake, which has a risk of burning the contents in the bag.
Please use a USB Type-A to USB Type C cable and 5V adapter to charge the battery.battery should be facing the head
Max 2100 lumen blinding high light and 250m flood-light long shot; the patented dual-function tactical switch can access to momentary on or one-step strobe under any working conditions by halfway or fully pressing the switch; rotational magnetic switch around the tail cap for easy one-handed mode switch; strike bezel embedded with super-hard nano-ceramic beads to efficiently break car windows.
TA30 MAX comes with a USB Type C direct-charge 21700 battery, to reduce the frequency of changing batteries, more environmentally-friendly; 5000mAh large capacity, to ensure the long endurance and lower battery anxiety
Waterproof: IPX8 (Submersible to 2m)
Head diameter: 38mm
Tube diameter: 28mm
Impact resistance: 2m
USB direct charge design
Super hard ceramic strike tips: Escaping from car windows & close quarter defense
Head diameter: 38mm
Tube diameter: 27mm
Head diameter: 46mm
Tube diameter: 28mm
Angle of light beam for White light: 10’
With battery over-discharging protection
Operation voltage: 4.2V to 3V
Nitecore HC65 V2 1750LM Triple Output LED Headlamp w/18650 Battery
Luminus SST-40-W 6500K LED / 4500K & red LED / CRI ≥90 / 11-mode / 1*18650/2*CR123/2*RCR123 / USB-C charging / IP68 / 165m throw
Enter coupon code MAP on the shopping cart page to see our unbeatable price.
Flashlight modes: Primary White Light Turbo > Primary White Light Hi > Primary White Light Mid > Primary White Light Lo > Primary White Light Ultra Lo > Auxiliary Red Light Hi > Auxiliary Red Light Lo > Auxiliary Red Light Flashing > Auxiliary White Light > Beacon > SOS
Waterproof: IP68 (Submersible to 2m)
Max beam intensity: 7000cd
100’ wide range flood beam
180’ all-round adjustable
Elastic and breathable headband with silicone sweat diverting strip
Highly efficient constant current circuit (non-PWM)
ATR (Advanced Temperature Regulation)
The power indicator can display the battery voltage (+/-0.1V)
E12R delivers up to 1200 lumens with a beam throw of up to 179 meters, it can be used as a camping light or floodlight.
It utilizes 18650 Li-ion battery with circuit protection board, which has a run time up to 173 hours.
Premium temperature control design
Impact resistance: 1m
UV-AA02 has multiple uses as below:
Check the leaks in an air conditioner or automobile circulatory system
Crime scene inspection of marks or blood
Treasure and minerals search; antique appraisal
Spot the fluorescence of special substances
Head diameter: 26.7mm
Tail diameter: 24.6mm
UV intensity: 52000uW/cm2 (15cm), 11000uW/cm2 (38cm)
Voltage: 2.8-4.2V
Waterproof: IPX8 (Submersible to 1.5m for 30 minutes)
UV anti-counterfeit lamp
*Low carbon and eco-friendly;
*High power equals to output supplied from 150W high voltage
*The polymerization isn’t affected by high temperature
*High thermal conductivity copper substrate – heat dissipation performance
Constant-current: Keep the stable output within 1A for protecting the LED lifespan.
Specialized black filter lens: 99% stray light filtered by specialized UV filter black lens, which makes fluorescent inspection easier, faster, and more reliable. Since tail emission is visible as deep violet light, adding the UV-A pass filter eliminates the glare and makes the background of the part surface darker. This increases the contrast between fluorescent indications and the darkened part surface when using fluorescent magnetic particle or penetrant techniques.
