:+1:
SP33S is boost driver? If still old driver than gross.
unlimited $2 code work for all ---EL1IFJY1VNKS (50 pieces in all )
20 minutes later will start
welcome to 1111 deal now, thanks
Jackie,
Is there a code for the IF25A please?
12
is the finish on the Silver IF22A painted on or is it polished aluminum ?
I am wondering about the durability of a silver finish
P19F2QIJ8D80 $3 code release 20 pieces more, thanks for all the support
is the finish on the Silver IF22A painted on or is it polished aluminum ? I am wondering about the durability of a silver finish
silver Oxidation
Jackie, Is there a code for the IF25A please?
EL1IFJY1VNKS
Got an HS05 with the $3 off code, so thanks.
12% presale of SP33S CODE--PRESP33S ,use XHP70.2 6000-6500K LED 5000LM output, compatible with 26650/21700 battery, Type C charging and reverse Charging Max 5V 3A
50 pieces of first batch in all
Link of SP33S: https://www.aliexpress.com/item/1005003438724316.html?spm=5261.ProductManageOnline.0.0.31114edfStG4nZ
Sofirn New Model Presale, shipping in 5-7 Days, first small batch of HS10 16340 Angle Light, work as a headlamp, 1100lm by LH351D 90CRI
LEDs. Enjoy coupons ordering on 11.11 deal day! Thank you.
Thanks Jackie, code worked, just ordered two more SC31PROs.
Hi Jackie, is there a code for the new hs10 headlamp?
Jackie, you didn’t include a link to the HS10. I found it “here”:15.11€ 58% OFF|Sofirn HS10 USB C Wiederaufladbare Mini 16340 Scheinwerfer 1100lm LH351D 90CRI Winkel Taschenlampe TIR Optik mit Magnet Schwanz 2 Gruppen|Scheinwerfer| - AliExpress .
Thank you bro
