FREEME ✌ LUMINTOP GT Nano Pro Flashlight Group Buy - ALIVE Today!
Interested
Interested
Count me in!
Interested
Interested
Freeme, count me in!!!
List updated.
I got a triple XP-L HI, with a peak reading of 1894lm.
freeme, please remove me from the interest list. Not because I am not interested, but because something else came up and I won’t be buying this light soon.
If you have a code, later on, I will contact you for sure :slight_smile:
Interested
Definitely interested!
Interested
Interested
No problem!
interested!
I can't resist any longer! Please add me to the interest list! I have a slight preference for LH351D emitters but, SST-20's or similar high CRI are all good assuming they are "Natural White/5000K~5700K".
Interesting light but I’m not in. :slight_smile:
Hi Freeme,
I seem to remember something about the aluminum black GT Nano with the extension tube and a possible issue with damaging the LED when running in turbo too long. Do you know if the GT Nano 3 will have the same issue?
That must be with a 10440, right?
That happened in the (early) batch(es) that had a thinner PCB.
The later/current batches have a thicker DTP MCPCB (1.8mm), which is much better handling higher currents.
The GT Nano also had that issue because of the led used (osram) which is more sensitive to higher Amps. I am sure that the GT Nano 3 won’t have that issue, unless a paper thin PCB is used…
