Modding the FW3A LEDs is easy, you donât have to mess with the driver, you only need to access the LEDs board from the top (removing the bezel, lens and optic) and then youâll see the wires that you need to unsolder.
Make sure you donât have a battery inside to avoid accidental short-cuts in case you touch both wires.
Got my FW3A 9 days ago , but the UI is kinda confusing. It does not line up with the original post, with the temperature blinky being after the BattCheck. Had a look at the generic AndĂșril UI but still canât set thermal limit as the light does not do the âtwo blinksâ.
Am I doing something wrong? I just do 7H from TempCheck then wait for the first blink, then enter the current temperature. The light then just stops flickering and goes to blinking the now calibrated temperature.
Have I made a mistake in getting an âInferiorâ light?
(Edit): I bought from Lumintopâs official AliExpress store.
To set the thermal limit you must enter TempCheck and do 7H and keep holding the button for the second blink and then let go. The first blink is for setting the current temp.
Anduril 1 worked as you said, where after entering the current temp the menu would then enter into temp limit setting.
Anduril 2 was changed to make it quicker to get to the specific menu item you are looking for, but it can be confusing if you havenât used Anduril 2âs menu style before.
I donât know what I did but now there is a weird flicker pattern when I ramp the light and I cannot reach full brightness. 13H does not work for reset.
Hello! After a long study of the subject, I decided on my first flashlight.
I managed to find an old batch fw3a in polished titanium case (with the original 7+1 driver) (I know that all new models get worse with each batch), also I got mcpcb with nice yellow hi cri leds which I like and swap it by myself.
All this backstory just you to understand how much it hurts me now that my only and long-awaited flashlight is lying in a box for three+ months with couple of 18350 battereis. I like short version and all this time Iâm looking for 18350 polished Ti tube for it. Every couple of weeks I send messages to official lumintop ailexpress shop but they answer me the same - âproduction time is 2-3 weeksâ. As I see it is impossible to buy it anywhere online.
So the question is maybe some of you guys have this part and do not use it or know where else I can look for it?
After about 3 years, I finally received a new FW3A in army green. I was on the original interest list but due to various reasons including a long hiatus from the hobby I never followed through on buying one until now.
Seeing how AWESOME this flashlight is I regret not getting one sooner, Itâs quickly became my favorite pocket light! Nice buttery smooth action of the tail switch but seeing how itâs even more prone to accidental on than even a side switch Iâm getting used to using electronic lockoutâŠI love how low modes are usable in lockout! Never had Anduril in a small pocket light before and didnât even realize it had this feature.
So now Iâve been âFW Bittenâ and already ordered an FWAA and an FW1A Pro (XHP50.2) Also considering an FW21 Pro (3xXHP50.2) and X9L (SBT90.2).
However Iâm saddened about Lumintop even further downgrading these lights. Fortunately the FW3A I received appears to have been older stock, it has the purple? color driver board with 6 chips like the one on the left in the new OP photo.
Iâm now concerned if Iâll get a downgraded FW1A Pro, although maybe the Pro model isnât affected since itâs a newer version to begin with? I ordered it from âA Lighting Storeâ on aliexpress, it showed the last one in stock, so maybe itâs an older version.
In the 2021 update post photo I see the downgraded red color board (on the right) is marked FW1A V1.1, does the downgraded FW3A board also look the same with no chips showing? Or are they using that FW1A V1.1 board in the downgraded FW3A?
Thanks but no. They have no it. Btw this guys have old versions of fw3a with original firmware and 7+1 driver. I ordered mine fw3ti there.
I checked lumintops aliexpress, ebay, amazon, lumintoplighting, lumintoponline.com, jlhawaii808, jc customs, illumn.com, nealsgadgets everywhere it is out of stock. Thats why Iâm asking it here and on reddit.
I killed a FW1A with a short doing a LED swap. Is there anywhere I can buy a replacement driver with Anduril or do I have to use something like a Convoy/Mtn driver?
If you ask Lumintop on their Aliexpress store theyâll sell you individual parts, including drivers. Prices are random though, Iâve paid anywhere between 5 and 9 USD per FW3A driver in the last three months.
