Just to be clear, I have the 9 in channellock oil filter pliers. I haven’t used them in the last 12 years because I have not needed them. Channellock also makes a 12 and a 15.5 in oil filter pliers. And plenty of other companies make them in 9 to 12 inches. But if you’re stuck and you don’t have an extra vehicle or you have got to get it done to drive to work the next day, then the screwdriver will get it off. I changed the oil in our three vehicles yesterday so I won’t have to do it during the winter. And I have never paid to have my oil changed. I do not enjoy doing it but I want to know it’s done right. The last used vehicle that I bought had a stripped oil drain bolt. It was not leaking but when I went to change the oil it was extremely tight and then it just spun and did not turn out. I had to clamp on with the 10-in vise grips hanging straight down and pull down as I was turning to get it to start catching what little threads were left. Apparently Ford intentionally makes the threads on the bolt softer than the threads in the pan so when some knucklehead over tightens things you can just buy a $5 plug. I’m sure many oil change places get the job done MOST of the time without issues.
It sounds like you have tried all the usual tools and tricks, and probably have a big oily mess with no option to take it anywhere.
The threads are likely galled or cold-welded from galvanic corrosion of dissimilar metals.
i don’t know if the flange is accessible, but i would be thinking of using a chisel and hammer to tap on the nut flange in the CCW direction, or an air impact hammer if you have that equipment. Anything to get some vibration into the thread joint to break it loose.
Also get some pictures of what the filter currently looks like. If it’s really damaged at this point I would go and buy another identical one and cut it in half so you can see exactly where the structure is left inside. That way you know what you can grab with what tools. Depending on access. Or cut more away to get at the base plate once you know what the base plate looks like. Again room and access are going to dictate the next moves.
If you get to the base plate you can probably stick a screwdriver in one of the holes and use a hammer to drive it around. I hope I never get to that point on an oil filter lol.
If you have a 3d printer you could design a tool to fit in all the oil holes around the center and put a wrench on it.
I stopped changing my own oil when the price of oil went way up. My local garage does it for about $10 more than the cost of filter and 5 quarts of oil plus he will grease any odd fittings for me. A large pair of pump pliers should get your stuck filter off if you can get them in there and have room to turn.
https://www.harborfreight.com/locking-oil-filter-wrench-63696.html Is there room to get this in near the base plate? I looked at one video of that vehicle and it is showing a view from underneath but also talking about removing the tire and getting at it in that direction. Are you working from the wheel well or underneath or both? The view wasn’t that great from underneath.
A coil spring filter wrench grips tighter as more torque is applied to the hex head. It won't collapse the can. Indispensable when swing area around the filter is limited and access can only be had from the end of the filter. There are two sizes. Link below is just for example, as I cannot ascertain quality to recommend this particular item.
When I go out there I’ll take a photo. Next try is a filter socket. The filter is still mostly solid with only minor dents and two nice clean holes with no tearing of the metal.
When I do get the filter off it will never be a problem again. I have a dual filter relocation kit that will make filter removal much easier and avoid oil in the filter fron draining on the rubber boot.
I would not try the screwdriver through the filter trick. I’ve seen them just tear through a filter too, and then you’re left much worse off than when you started.
If you’re going to go at it from the end I think I would try this thing. Below. Although some of the cap type Socket/wrenches
do fit pretty nice, most do not If you can have an identical new filter in your hand to test fit some of those cap type sockets that’s a good thing. Lisle Oil filter wrench review. It saved me from a lot of work! - YouTube So even with a hole all the way through both sides and some sort of a giant bar you cannot move it, or is it that you can’t get a large enough bar on there?
