I wanted a D2 flipper that was 3”. From where the blade starts, to the tip, it’s almost exactly 80mm, just barely over 3 inches, so fits the bill nicely.
My main suggestion for TunaFire would be to remove the “TunaFire” lettering from the blade, they would probably sell more of these. Maybe have just a “TF” at most. Even a picture of a little tuna fish on fire would be better.
Overall though, for $22.99 plus tax, I’m pretty satisfied.
First there was Surefire. Then there was Trustfire. Then Ultrafire. And a few others I can’t remember. I guess the success of Surefire has them obsessed with the “fire” suffix, but Tuna? Now a fish prefix? I mean, c’mon… “Sharkfire” I can understand. But “Tunafire” is so close to “Tunafish”. :person_facepalming:
Anyway, nice clean looking knife. I like the simplicity and a lot of well thought-out points (hollow drop-point grind, ceramic bearings, D2 steel, useful spine jimping, nearly 100% liner lockup, under 3oz, Micarta scales, well placed lanyard hole, deep carry clip). On the AliExpress site it’s for sale, but only $2 cheaper with a 2 month shipping time. Much better to order from Amazon. Would be interesting to see a tear down.
It ticked a lot of different boxes for me which are basically what you listed. I’m happy with it. Ended up with a few more knives in the process of finding this one. The more, the merrier.
Edit: Just did a teardown, here’s a picture:
Also, it appears you can get it without the “TUNAFIRE” logo on the blade. User reviews on AliExpress say it arrived without the inscription as the pictures show on the listing.
I found 6 rare Lone Wolf (pre-Benchmade) Dual Action Autos new and still in the factory boxes in my bottom dresser drawer, along with a Leatherman Charge in some kind of presentation case that has all the crap you’d want plus a Leatherman knife. Pretty bizarre and pretty special. And another Lone Wolf which has some stunning walnut wood handles on it…but that one is not a DA.
Received the $18 clone of Benchmade 555, purchased from dhgate.
Took 21 days to arrive… from California (reshipper)
it feels great, works great, slices paper great, has hollow grind… seller’s ad says the steel is actually 440C… (marked 154CM)
the one I bought on Ebay for $90 (same knife sold without disclosure), reached Benchmade yesterday, and they contacted to inform me they are impounding the knife as a counterfeit, and have mailed me a letter to that effect.
Once I have the letter, I will ask Ebay for a refund, and maybe they will choose to close the sellers account. So far, neither Benchmade nor Ebay has shown any interest in stopping the seller. Maybe after Ebay has to refund me the $90 they will see things differently. They demanded the letter from Benchmade, before they will honor their money back guarantee. will update.
One way to recognize this Mini Griptilian counterfeit, is by the box, which lacks a label. This difference is definitive.
the Omega spring on the counterfeit has been improved, to match the original, that feature is no longer a “tell”.
The counterfeit blade is 0.08” thick, the genuine blade is 0.10” thick… this is a definitive way to ID the counterfeit.
The counterfeit handle material is not the same as the original, but if you dont have both, you would not know.
The weight of the counterfeit, with clip, is 70 grams… the original weighs 10 grams more. This is also a definite ID feature.
These are currently $19.99 plus additional 20% off clip coupon, bringing it down to $16. Debating whether it’s worth it. Is it actual D2 steel? Some people complain that it doesn’t have a particularly smooth release - maybe it can benefit from some cleaning and relubing of the bearings?
No, it isn't. Eafengrow has been tested multiple times via XRF by the LuvThemKnives channel on YouTube. They are repeat offenders for false steel stamps. If you are lucky, it'll be 8Cr13Mov. If not, it might be 5Cr15. Better yet, just say "no" to Eafengrow. Stick with decent budget brands like Sanrenmu and Petrified Fish.
At least one of those knives was made by Petrified Fish and rebranded. PF is one of the better budget manufacturers and has only more recently become a known brand outside of China. The particular knife in question used 8Cr13Mov with about the best heat treatment you'll see for that steel. A good grind was also helpful.
When dealing with an unscrupulous company, it's hard to know for sure. Almost any blade steel can be made sharp at the factory. Edge retention testing can be complicated by the fact that most factory edges involve fatigue and true performance can take several sharpenings to emerge. The most reliable way to tell is to deal with known and reputable companies. Failing that, check the spreadsheet from LTK to see if samples have been checked via XRF. Otherwise, the easiest way to check for real D2 is with a mustard test. A blob of common yellow mustard placed on totally clean and oil-free steel with a satin finish for one hour will significantly stain D2 but not common substitutions such as 3Cr13, 5Cr15, and 8Cr13Mov. Of course, passing this tests involves staining the blade.
This is also good to know. And I completely agree. At that price point, I just want something that looks good and feels well built. I’d of course prefer it to be D2 steel like it states, but I’m not going to be heartbroken if my <$25 knife isn’t actually D2 steel, just a little bummed.
These boxes always come from my Chinese shipper. Always something weird and wrong about them. Easy to spot though. I’m not measuring anything. I already knew I was buying a copy so no need for me to get into the, “how to spot a fake” worm hole. If you buy an expensive knife for $18, you can’t really complain.
I do have to say. the knife that came in that box, I have been hammering on at work for the last 3 months. It stays sharp and keeps on working. When I first got it I took it apart, cleaned and lubed it, and put a spot of blue loctite on the pivot screw and adjusted it accordingly. It hasn’t let me down yet.
when I bought the first one off ebay for $97
I did not know it was a counterfeit
Ebay required me to send the knife to Benchmade for Authentication.
It failed, and Benchmade confiscated my Ebay knife.
the one I got for $18 was my way of proving to myself, that the ebay knife was counterfeit. I like my clone for $18, not so much for $97. It is well made, inexpensive, and sharp.
now waiting for the letter from Benchmade, to send to Ebay, so they refund my $97 counterfeit, and stop the seller from fooling others like me.
