FearOfTheDark's Hand Made Light for the 9th Annual BLF/OL Contest
19 posts / 0 new
FearOfTheDark
Last seen: 6 days 14 hours ago
I know not everyone liked my previous build so this year I will build something much more standard.
The planning is not yet final. It will be a lantern / emergency lighting with a magnetic charging that turns on automatically during a power outage.
Hope you will like it…..
turkeydance
turkeydance's picture
Last seen: 6 hours 13 min ago
thank you for planning.
would you try these three things?
1. 4000K max. above that is too harsh for me.
2. super-simple operation. no strobe or SOS.
3. a stable base which is not easy to turn over.
the reasons for those are:
1. we cover or diffuse the harsher lights (lampshade?).
2. young children could understand how it works.
3. children/pets/Grandmother.
Scallywag
Scallywag's picture
Last seen: 4 hours 40 min ago
I thought your build was great. Please build what makes you happy
MtnDon
MtnDon's picture
Last seen: 24 min 46 sec ago
Thumbs Up that is what I do
FearOfTheDark
I am using 5mm LEDs array so not many K option are available
It is super simple operation: On when during power outage
I am planning to use a semi-sphere body so should be stable
FearOfTheDark
I build the lights I need Smile
We have many power outage in my area so an automatic emergency light is curtail for me in order to find my light in the dark
FearOfTheDark
In this year’s project I tried to use as many recycled components as possible.
I took LEDs from a broken flashlight / lantern.
I disassembled the charging circuit from an old Powerbank.
As a body I will use a plastic from a burnt LED bulb. I will close it using Plexiglas pieces I have at home.
The Lipo cell is from a camera battery.
I only had to buy the microcontroller and the charging cable.
FearOfTheDark
Brief update from today: I have soldered the micro controller to a board and added 2nd micro USB socket for the magnetic charging
Asian8640
Asian8640's picture
Last seen: 4 min 26 sec ago
Looking good! I was planning to do something similar originally, but went another way. I’m really looking forward to your completed project.
Old Lumens Contest Entries: "7th 5mm LED Lantern":https://budgetlightforum.com/node/70438 and "9th Copper Pipe Triple":https://budgetlightforum.com/node/79484
FearOfTheDark
Thank Asian8640.
The day was devoted to writing the code Smile
I thought it would be more complicated but in the end it came down to two lines:
void setup() {pinMode(0, OUTPUT);} void loop() {digitalWrite(0, !digitalRead(3));}
When power stops coming from the power supply to pin 2 – the LEDs turn on.
G0OSE
G0OSE's picture
Last seen: 10 hours 41 min ago
Nice to see your progress, I’m all for keeping it cheap and simple – reusing components or modifying existing bits!
wcddesign
Last seen: 21 min 36 sec ago
This sounds so interesting to me. I have no experience with microcontrollers or writing code for them. Though I did write code for PCs long, long ago.
What is that language? Is it specific to microcontrollers?
YuvalS
YuvalS's picture
Last seen: 4 hours 43 min ago
Hope it is OK to comment on the code, I think you have a design issue: In case of long blackout your light will drain the battery to 0V. you have to add a low voltage protection.
You can do it by FW or HW
My FW repository
My BLF/OL contest entries: 7th 8th 9th
FearOfTheDark
Thank you Yuvals, sure it’s okay to comment. I am using protection circuit so no worries.
Today’s update:
I soldered all components and done with electronics Smile
Insulate the battery with electrical tape
Connecting a protection circuit
Connecting a charging circuit
Connection LEDs, controller and a switch
Check that everything works
FearOfTheDark
Thanks to the weekend, I was able to make significant progress in the project:
Marking the base of the lamp
Cutting and drilling holes for screws and switch
Placing all parts inside the lantern
Connecting the magnetic charging port
Connecting the switch
Sealing with glue
Asian8640
Asian8640's picture
Keep going! YOU CAN DO IT! 2 days left until that timer hits zero.
MtnDon
MtnDon's picture
Looks like we just need to see an “all done” and a lit-up image. Thumbs Up
gchart
gchart's picture
Last seen: 2 hours 30 min ago
Yup, can’t wait to see the final product. Nice build!
FearOfTheDark
Since you guys asked nicely Smile
Here is a video:
At first, the light is on.
Then, when connected to power, it turns of and the red charging indication is lit.
When fully charged, blue indication is lit.
