The handle knurling pattern on these tubes is identical between the FT03s and MT70 mini. It seems the proper way.
The MT04 tubes at Neal's have a radically different pattern of handle knurling yet appear thread compatible. Tom, are you certain these WONT WORK, other than the aesthetics?
I think I'll take a chance on the BG FT03s tube...
I can't be certain of anything, including if I put on matching sox this morning...
These models are insane - I don't have an MT04 but it appears the MT01 is the same size and style, so I'd bet on it, plus texas shooter is pretty good with this stuff as well - I'd trust him more than myself...
lOrdered from Neal 11/04, received yesterday (11/18); good compared to my AliExpress orders recently, and the tracking info was detailed and accurate.
Thanks again Freeme.
Is the battery mostly charged? If so then ramp the light to high. At high double tap to compare turbo increase. The lower the cells charge the less turbo stands out.
Same here. The box had manual for MT90 mini with SBT90.2. I showed the light to a friend, he liked it a lot, ordered one, and same thing. His light came with manual for MT90 mini with SBT90.2.
RTRM. read the right manual.
Well, anyway, the MT70 Mini SFN 55.2 is one of my favorite lights. A very nice combination of beam power performance and beam profile for its size and cost.
So far, I haven’t had a Mateminco/Astrolux flashlight that uses Anduril 2 yet (the only exception for “Astrolux” brand flashlight with Anduril 2 would be the EC06, but this appears to be a Sofirn-manufactured light instead of Mateminco).
Most Astrolux/Mateminco flashlights that use Anduril (based on my test) have the factory reset function (hold button while tightening the battery tube), but do not have the 15-clicks version check function, indicating a relatively older Anduril version. (these include: MF01-Mini, MF01S, FT03S SBT90.2, HL01, EA02 models)
The Astrolux/Mateminco models that use Anduril, and with version check would be these: EA01, EA01S, FT02S, which has Anduril 1, version 2019-12-05 (this firmware version is not listed in Toykeeper’s Anduril repository, so it could be a self-compiled version by Mateminco).
