I bought two Sunlike MASS15D bulbs from Lampman before he was jailed. The other of them arrived broken. It seems that one can not get new ones, so I’d love to repair it. After I disassembled the bulb, it seems that the problem is with the driver, but I could not find anything physically wrong with it.
The driver is Triac Dimmable LED Driver, Model: QH-LK7-20X1. I could not find information on the specific driver or a way to purchase one, and wonder if some other driver would fit. I’m not very knowledgeable on the drivers so any input would be appreciated.
I have a small bulb from him that died after turning it off/screwing bulb, then turning it back on couple days later. I think the driver wire may have disconnected though, as the driver shakes around. haven’t had time to try to dismantle, but the e26 screw will be ruined in the process for sure
It had something to do with the Lukashenka regime. He was apparently jailed for for speaking on the Internet about an employee of the Ministry of Internal Affairs. He posts updates on the SunLikeLamp.com Telegram channel, but I don't speak Russian. https://t.me/sunlikenews
And thank you! How should I go in buying the driver?
The driver says it is a Triac Dimmable LED Driver, Model: QH-LK7-20X1 and the PCB says QH-LK18W.PCB.
It is possible to carefully remove the E26, or E27 in my case. One can also buy them for almost no money from China or find similar ones from some other LED bulbs.
I know he was getting his hosts and drivers from taobao, he posted a few links somewhere, maybe his other blog, but I’m guessing only vk one is alive now
This seems to be the correct one. The driver I have seems to have a an added thermistor and two film capacitors that I can solder to the new one. Thank you so much!
