got mine yesterday and all were good taking a charge fine with no problems whatsoever.
Same results for my 16
Tested one AA last night. Only 1800 mah capacity. Anyone getting something close to 2800?
I think this is one Vipon deal where they are just trying to unload old or defective stock.
Tested eight of them in my two Liitokala 500’s last night. Pretty consistent, but as others have noted, no where near the rated capacity. Don’t really care as long as they cycle well and don’t die prematurely (big if…). Surprised the 250ma rate yielded a lower capacity, normally I would expect the opposite, maybe I’ll switch the units and see if the numbers follow the batteries or the units.
700ma chage/500ma discharge
2002 mah
2059 mah
2080 mah
2063 mah
500ma charge/250ma discharge
1905 mah
1986 mah
1914 mah
1905 mah
None of the Chinese Brand batteries ever test the stated MAH —— some Turnigy tested about 90% — these were cheap enough — good for Grandkids toys
The DOAs aren’t confidence inspiring. The EBLs I got earlier were about 200mah underrated.
Which has to be marketing BS. There are no 2800mAh LSD, and few that are even worth a damn.
I had good luck with the EBL 9V Lithium rechargeables so far, but the EBL AA Ni-Cads had a couple of early deaths in a group that otherwise still appear fine. Curious.
The moral of that story must be when looking for the next great thing or a “great price”: stick with Eneloops or Laddas.
For many years now I only buy Eneloops or rebranded ones because regardless of price other ones either had poor performance or short lifespans, and usually both.
Only eneloops for me. Don’t even worry about rebranded. At $2.50 each and 2100 recharges it amounts to nothing.
does your guitar need an oil change?
Congratulations 45 Pieces Guitar maintenance tool set….
$31 using chord progression NNJUCJCN.
Check this deal out on Amazon
Deal of the day: LE LED Camping Lantern Rechargeable, 1000LM, 4 Light Modes, 4400mAh Power Bank, IP44 Waterproof, Perfect Lantern Flashlight for Hurricane Emergency, Hiking, Home and More, USB Cable Included https://www.amazon.com/dp/B015ZFKLNK/ref=cm_sw_r_apan_glt_fabc_dl_C616RN04JBWC81M9M5TH?\_encoding=UTF8&psc=1
p=.
Deal of the day: LE LED Camping Lantern Rechargeable, 1000LM, 4 Light Modes, 4400mAh Power Bank, IP44 Waterproof, Perfect Lantern Flashlight for Hurricane Emergency, Hiking, Home and More, USB Cable Included Amazon.com
It’s a shame the internal 18650 cells aren’t easily replaceable. Looks like a nice lantern though.
Vont 2 Pack LED Camping Lantern, Super Bright Portable Survival Lanterns, Must Have During Hurricane, Emergency, Storms, Outages, Original Collapsible Camping Lights/Lamp (Batteries Included) Amazon.com
I leave judgement on this for those that know more about lanterns than me, but thought it was worth looking at. $15.39(prime) for two lanterns using coupon…. Lifetime warranty against defects even loss/theft…… 52K mostly good reviews …. for what that is worth.
Gerber Suspension Multi-tool NXT for $23.38. Anybody have this model? Is it a good deal?
https://www.amazon.com/Gerber-Suspension-NXT-Multi-Tool-Pocket-30-001364/dp/B07DD69QN3/ref=sr_1_36?ie=UTF8&\_encoding=UTF8&tag=bensbargaicenter&linkCode=ur2&camp=1789&creative=9325
roperly The reviews
Edit:The link for this Gerber wouldn’t post properly but that’s probably ok. The reviews for this model are very poor. It may be worth the sale price but no more. Gerber multi-tools have become a disappointment. I’ll stick with Leatherman.
I have several of the variations of the old Gerber 600’s and the Suspension NXT that I have does not compare from a rigidity or abuse loving standpoint.
Energizer 1000 High Lumen Hybrid LED Headlamp, IPX4 Water Resistant, Durable Metal LED Light, Rechargeable Headlamp
[Hybrid Powered LED Light]: Can be powered by rechargeable lithium ion batteries or CR123 batteries
Batteries : 1 Lithium ion batteries required. (included) -
According to reviews and accompanying photos, it comes with 2 cr123 and one 18650
$19.50 with Prime Deal
https://www.amazon.com/dp/B092RJ9TPV?tag=strugglevil03-20&linkCode=ogi&th=1&psc=1
$8.50 for 4 AA and 4 AAA rechargeables using code KGK7QZG9, which makes it $0.425 per A. !https://www.1sale.com/wp-content/uploads/2021/11/IMG_1636584286-679x390.png! Amazon.com&linkCode=ogi&th=1&customid=undefined&coupon_code=KGK7QZG9
My 16 AA's came yesterday. All @ 1.34 ~ 1.38 V. Damage from factory overcharge?
Capacity testing now on Opus 3100 @ 200ma charge/discharge test.
slmjim
I wonder why one would buy an expensive battery charger and then buy inexpensive batteries ?
After being on this forum for a limited amount of time it seems cheap batteries always disappoint .
I purchased the same batteries with the charger so I wouldn’t know for sure I wasted my money .
Not sure I quite understand that rationale.
With a decent charger you can find out if your (cheap) battery is OK/fantastic/disappointing/complete garbage, whatever it cost. You can track battery performance/capacity/degradation over time. That does have the possibility of doing your own research and learning from that.
With a cheap charger >>> you will never know much of anything with any kind of quantification or reliability. It pretty much becomes, work/doesn’t work. It doesn’t give you any opportunity to learn much of anything.
I do agree, cheap batteries generally disappoint. Inexpensive, but decent chargers, can be useful for basic charging, but don’t supplant a good analyzing charger.
