Is the battery mostly charged? If so then ramp the light to high. At high double tap to compare turbo increase. The lower the cells charge the less turbo stands out.
Same here. The box had manual for MT90 mini with SBT90.2. I showed the light to a friend, he liked it a lot, ordered one, and same thing. His light came with manual for MT90 mini with SBT90.2.
RTRM. read the right manual.
Well, anyway, the MT70 Mini SFN 55.2 is one of my favorite lights. A very nice combination of beam power performance and beam profile for its size and cost.
So far, I haven’t had a Mateminco/Astrolux flashlight that uses Anduril 2 yet (the only exception for “Astrolux” brand flashlight with Anduril 2 would be the EC06, but this appears to be a Sofirn-manufactured light instead of Mateminco).
Most Astrolux/Mateminco flashlights that use Anduril (based on my test) have the factory reset function (hold button while tightening the battery tube), but do not have the 15-clicks version check function, indicating a relatively older Anduril version. (these include: MF01-Mini, MF01S, FT03S SBT90.2, HL01, EA02 models)
The Astrolux/Mateminco models that use Anduril, and with version check would be these: EA01, EA01S, FT02S, which has Anduril 1, version 2019-12-05 (this firmware version is not listed in Toykeeper’s Anduril repository, so it could be a self-compiled version by Mateminco).
Not sure where that comes from Anduril or Anduril 2? I don't see anything like "2C to turbo from off" in Anduril 2.
2C from OFF goes to the top of ramp. If you configure top of ramp to be turbo, then a 2C from OFF will go to turbo. That's the only way I know of to do that.
In my Anduril 2 builds, I'll set up the behavior to be like Anduril 1 - if the light is ON, a 2C goes to turbo, or from OFF, do a 1C then a 2C to get to turbo. This will work with the default top of ramp.
Banggood has been using airmail lately then straight to USPS instead of a slower intermediate. I’ve gotten quick mail lately too, a few dollars more than the free shipping of old.
I got in the FT03 MT70 Mini! Nice! On a Lishen LR2170LA @4.20V, 19.9 amps at the tail, 6200 lumens at start, 211 kcd. I can't get it to run 30 secs without tripping temp reg.
I'm gonna add spring bypasses and check the LED wiring and try a T42 cell.
So I got another FT03 w/XHP50.2 3V and just added spring bypasses. Measured 19.7 amps, 5560 lumens at start, 189 kcd.
So for about the same amps, the SFN55.2 is about 10% brighter, throws better and has a much better tint in the beam. The XHP50.2 is supposedly 6000K with a blue flood, yellow corona where the SFN55.2 is white through-out. No contest here.
