That was quick!
Got lucky with the post.
Interested code pls Mr. Freeme
Replied.
Mine is still stuck in transit, last update 4 days ago, so don't think it's in the US yet.
I have a 3 21700 flat top adapter ready-to-go for this light.
freeme - the flat top adapter is a great idea, Astrolux should really consider including it, or at least offering it.
I’m kind of rolling the dice that Molicel P42’s will fit. They have a good projecting top but were too fat for the Amutorch DM70.
They work fine that’s what I’ve used in mine.
Mine is still stuck in transit, last update 4 days ago, so don’t think it’s in the US yet.
Where did you pick that up?
This is a pic from the Convoy 3X21A I bought, but it had several cracks so I asked Simon for 2 spare and he sent them to me.
Astrolux EC06 - some pics & a beamshot by d_t_a
Some pics of the Astrolux EC06, side-by-side comparison with some other flashlights: (from left to right:) Haikelite HK04 - Sofirn Q8 Pro - Sofirn Q8 Pro - Astrolux EC06 - Convoy 3X21A - Convoy 4X18A [image] ~~~~~~~ top row: 3X21A (SFT40) - EC06 - HK04 bottom row: 4X18A (SBT90.2) - Q8 Pro (OP) - Q8 Pro (SMO) [image] Astrolux EC06 LED [image] Astrolux EC06 battery board, appears to have spring bypass wires pre-installed [image][image] Astrolux EC06 driver board …
My EC06's tracking says "arriving late" but does say it arrived in LA (other coast).
Interested
I posted over here on the driver design. It seems unique to me - 6 LED's, 3 sets of output circuits of FET+1's. I believe they are wired in parallel for input off the same pins from the processor though, so can't individually control them, but on the output side, they are independent. The MCU processor has a very limited # of I/O pins.
Replied.
Interested
The EC06 arrived at my local post office, though closed today. Should get it tomorrow
Code please
Thanks freeme
Awesome!
Ok - took some pics, made some measurements. I'd say I'm usually disappointed with a first look at output, yea like 99% of the time. The best #'s I'll measure with a maukka calibration factor is almost always lower then the spec, with some rare exceptions.
This EC06 though is utterly insane! I'm actually afraid to test it at 30 seconds because at 10 seconds, it's close to flesh damaging level, yet it's a fairly robust host, coning in at almost 100 g more than a Q8 at 501.5g for the EC06, Q8 at 409 g, and the bigger Convoy 3X21A at 577 g.
First set of cells I tried were a brand new set of Vapcell T42's, supposed slightly better performance than 40T's and measured 28090 at turn on! Ouch! Yes, flesh scorching hot in just a few seconds.
Measured again without re-charging over 10 secs: 27755 at turn on, 25360 at 5 secs, 24660 at 10 secs. Lumens are with the maukka calib factor. My old calib factor got 12% higher lumens, so these #'s are on the conservative side, but make note this is not at 30 seconds.
Throw with a 2 sec pause, taken at 5 m: 127 kcd
So what makes this light so hot? Well, it comes stock with 22 or 20 AWG spring bypasses on the only 3 springs in the light at the batt- end of the 21700's, and direct brass ring contact on the batt+ side. Also there's a unique power design to the driver, 3 separate output channels, 3 pairs of LED wires -- that has to help. I'm still not sure I can explain this because the best turn on lumens I've seen from a single XHP50.2 3V light is 4500, though probably could have gotten more. If I could get 5000 with a top cell, then x6 for the EC06 puts it at 30K, but the EC06 has 2 LED's per cell, therefore it should not do as good a a single LED driven by a single 21700.
I looked closely at the battery tube end, and the tweaks they've got factory stock is many of the things I've done in mods to similar lights. Haven't looked in detail at the driver and head assembly yet, but I expect more of the same. I'm almost thinking these guys studied my mod posts, but of course I'm not the only one doing them, and mostly they are common sense anyway.
I'm not sure what A2 stock settings the firmware has, but the surface temp really got hot quick, and I haven't even gone into Advanced UI mode yet. Sure hope top of ramp and/or 2C is set for max turbo in the Simple UI...
Couple more points:
- the lens looks untreated. Either it's very good glass, AR coated but no noticeable tint, or if replaced with an AR, it will do about 5% better!
- the beam looks decent enough to me, considering XHP50.2. For 6 LED's, of course you get the pedal effect on the outside of the flood
- would like a SS bezel option, and of course color choices
- like it has a tripod mount point
- got a Convoy 3X21A flat top adapter to fit and work - just has to dremel/sand down the adapter about 1 mm in diameter to fit - now works excellent!
- It does a little better in lumens then my MT03 TA with slight mods (triple XHP70.2), same length, smaller head diam then the MT03 but also throws better
- amber/orange LED's in the switch come on sometimes, not sure, but think it's when the light gets hot - don't know what that's about. The standard green ones are top and bottom mounted, while the amber/orange ones are on the left and right sides
Thanks, Tom E, and everyone for your valuable input.
I'll take a code, and thank you, freeme!
