So far, I haven’t had a Mateminco/Astrolux flashlight that uses Anduril 2 yet (the only exception for “Astrolux” brand flashlight with Anduril 2 would be the EC06, but this appears to be a Sofirn-manufactured light instead of Mateminco).
Most Astrolux/Mateminco flashlights that use Anduril (based on my test) have the factory reset function (hold button while tightening the battery tube), but do not have the 15-clicks version check function, indicating a relatively older Anduril version. (these include: MF01-Mini, MF01S, FT03S SBT90.2, HL01, EA02 models)
The Astrolux/Mateminco models that use Anduril, and with version check would be these: EA01, EA01S, FT02S, which has Anduril 1, version 2019-12-05 (this firmware version is not listed in Toykeeper’s Anduril repository, so it could be a self-compiled version by Mateminco).
Not sure where that comes from Anduril or Anduril 2? I don't see anything like "2C to turbo from off" in Anduril 2.
2C from OFF goes to the top of ramp. If you configure top of ramp to be turbo, then a 2C from OFF will go to turbo. That's the only way I know of to do that.
In my Anduril 2 builds, I'll set up the behavior to be like Anduril 1 - if the light is ON, a 2C goes to turbo, or from OFF, do a 1C then a 2C to get to turbo. This will work with the default top of ramp.
Banggood has been using airmail lately then straight to USPS instead of a slower intermediate. I’ve gotten quick mail lately too, a few dollars more than the free shipping of old.
I got in the FT03 MT70 Mini! Nice! On a Lishen LR2170LA @4.20V, 19.9 amps at the tail, 6200 lumens at start, 211 kcd. I can't get it to run 30 secs without tripping temp reg.
I'm gonna add spring bypasses and check the LED wiring and try a T42 cell.
So I got another FT03 w/XHP50.2 3V and just added spring bypasses. Measured 19.7 amps, 5560 lumens at start, 189 kcd.
So for about the same amps, the SFN55.2 is about 10% brighter, throws better and has a much better tint in the beam. The XHP50.2 is supposedly 6000K with a blue flood, yellow corona where the SFN55.2 is white through-out. No contest here.
It's Anduril 1 - no version on 15 clicks, exiting lockout via 4 clicks, the main LED is OFF.
Just upgraded the LED wires to 18 AWG, from 20 AWG, swapped the OP reflector with an SMO, and had to add a copper shim (1" 18 AWG) under the MCPCB to keep the SMO from rattling (very slightly shorter). The beam looks great w/SMO and got a bump in throw.
On a 26800 at 4.20V, now I'm measuring 21.7 amps, 6210 lumens at start, and 254 kcd throw (2 sec pause).
So lumens went down a little (6300 -> 6210) but throw went up (217 -> 254 kcd).
This one might need a group buy with 26800. It’s a significant increase in output. Would also like to see a group buy with the Mateminco MT01, 26800 battery, with the SFN55.2 or SFH55 LED.
